api meteotemplate--> setup
i downloaded the trial mac version of wd, to try the meteotemplate api
I set the window of metetemplate, it does not work …
are there any other settings ???
Thank you
Davis IP
see what shows if you run the cronhttpget from a terminal window
I run the cronhttpget and api apparently it’s ok
Where is the problem? :?
does not work with the mac version 8O #-o !!!
ok with the windows version
