Mine is working fine. Are you getting data from the cloud or via UDP?
UDP. There doesn
I have my SKY unit now
I have fixed up a few things (and some bug fixs with the history data for the SKY data after some changed to the api) and I am sure I will find a few more
make sure to be using the latest .zip update of WD (and the latest cronweatherflow.exe included with that)
we are expecting some rain and strong winds here later next week
[quote author=jnardone_pdx link=topic=66135.msg531845#msg531845 date=1516660395]
UDP. There doesn
just done another update to fix problems with getting the history data from the SKY (for when like getting back more than 1 hour of data)
was able to use a user with a SKY unit that set his up under a tap to simulate rain
and have fixed where the rain in the history data was not been picked up by WD
use build 64 update
I just installed. I’m still not seeing any rain being shown in WD through UDP even though Smart Hub is showing rain. Below is a picture. Shows rain_debug. Not sure what that is.
The rain numbers are only broadcast once per minute.
still no joy Brian. WD reported no rain over night. I have sky connected to Weather Underground through WD and directly to the hub. The direct to hub version shows 0.1" since midnight. The WD connected sky shows 0". Is there a way to help narrow this down? Do you save the raw UDP data in a log file I can examine? I previously had WD connected to my WXT520 and I wonder if there are some residual registry settings not getting cleared when I changed weather stations. Thanks for any pointers. -joe
Sky connected directly to WU through HUB
https://www.wunderground.com/personal-weather-station/dashboard?ID=KORHOODR38#history
Sky connected to WU through WD
https://www.wunderground.com/personal-weather-station/dashboard?ID=KORHOODR9#history
I have tested here and its working
for rain data
from my HUB (with the latest HUB firmware…what firmware do you have?)
the rain data should be in the obs_sky data
which gets saved to a file called
weatherflowobs.txt
maybe post that file here
Hub is version 30, Sky is rev 26, Terrace is 17. Attaching file from two different times. It is raining right now, but still not showing any rain on WD.
First file update
{“serial_number”:“SK-00005971”,“type”:“obs_sky”,“hub_sn”:“HB-00001940”,“obs”:[[1517004844,null,0.00,0.015,1.12,1.49,2.19,272,2.79,1,105,null]],“firmware_revision”:26}
Second file update
{“serial_number”:“SK-00005971”,“type”:“obs_sky”,“hub_sn”:“HB-00001940”,“obs”:[[1517005083,null,0.00,0.011,0.89,1.62,2.19,292,2.79,1,78,null]],“firmware_revision”:26}
Third file update
{“serial_number”:“SK-00005971”,“type”:“obs_sky”,“hub_sn”:“HB-00001940”,“obs”:[[1517005263,null,0.00,0.016,1.52,2.43,3.53,258,2.79,1,72,null]],“firmware_revision”:26}
weatherflowobs.txt (168 Bytes)
Your UDP stream is showing rain, it is the 4th set in the data stream. Might be some other setting in WD that is blocking that
The other issue I see is that your battery is getting very low, it should be up around 3.4v
If you want to see how to read the data stream, go to https://weatherflow.github.io/SmartWeather/api/udp/v30/
Any ideas on what settings may prevent WD from using Sky’s precip, but still use wind, temp, & pressure?
We uses the last rain data reading
For some reason yours says null
What I could do is if that is the case then use the rain data at the start
Strange yours reports rain differently. Are you using both Air and Sky on the same hub? I wonder if both are getting updated together or at different times and sometimes shows null data for sky. Happy to try any updates. -joe
I just installed updated file and rebooted, but of course it just stopped raining . I’ll monitor overnight. You can see if any rain does get reported on WU at https://www.wunderground.com/personal-weather-station/dashboard?ID=KORHOODR9#history
Thanks!
What you should do is join the WeatherFlow forums at https://community.weatherflow.com
Post the UDP string that you posted here and ask them why your Local Day Rain Accumulation is showing null.
WD only captured a fraction of the precip overnight. Since midnight, WD is only reporting 0.06" of rain. SmartWeather App is showing 0.49".
BTW, I connected directly with the weatherflow development team before I started this thread. They did not see any issues wrong with Hub or Sky from their end. I also do not see anything wrong with the UDP strings I posted (will post again below for reference). The only field showing NULL is the local day accumulated rain. I don’t believe that is even used by WD. Rain accumulated does have a value.
From Previous:
First file update
Second file update
Third file update
Observation (Sky) [type = obs_sky]
Observation Value Layout
Index Field Units
0 Time Epoch Seconds
1 Illuminance Lux
2 UV Index
3 Rain Accumulated mm
4 Wind Lull (minimum 3 second sample) m/s
5 Wind Avg (average over report interval) m/s
6 Wind Gust (maximum 3 second sample) m/s
7 Wind Direction Degrees
8 Battery Volts
9 Report Interval Minutes
10 Solar Radiation W/m^2
11 Local Day Rain Accumulation mm
Any suggestions? WD is still only showing a fraction of precip with the custom update that is being reported directly by HUB to WU. Below is a picture of the latest graph and differences between the approaches using the same SKY (one direct to WU and one that uses WD to interface with WU)
