HI,
Just wanted to mention here my most recent dumb act but still a puzzling act.
I’ll make it short – recent indoor test of lazer snow measuring device - fluke -after setup with some help worked great indoors - test complete till spring or when I can get it set up for next snow season.
So I noticed after manually inputting snow totals, that after a few minutes or so they would revert back to what the CM side had- also noticed the in the Input Daily weather, in the big box, the log file was still logging.
So closed the cronlazersnow down and it it still continued to log and change the Snow Depth Totals back to what the log file was recording Example:
9:16:18 AM current calc snow depth from difference 0.00000, current snow depth 10.70000 , last snow depth 10.70000 threshold 0.20
09:17:19 current calc snow depth from difference 0.00000, current snow depth 10.70000 , last snow depth 10.70000 threshold 0.20
So in one effort I deleted the LrTimelog file and the cronlazersnow.exe , shut down WD restarted and and it was still logging every minute and changing the snow depth totals.
OK so above was the dumb process.
Went back to the set up process. reversed the process, and found out all I needed to do was to uncheck the boxes in WD Setup - Advance/Misc - Boltwood/Homemade… and unchecked both boxes in the USB Snow Sensor setup – perhaps you only need to check 1 box but I did both and all seems good now.
My only observation, and I have no idea how it works, but without the Fluke plugged in - the cronlazersnow and Lrtimelog file removed, why was the log in the Input Daily weather still being written along with not be able to change the snow totals.
yamiacaveman
