Wind Chill with Ultimeter 2000
I
can you post a screen shot?
the version you are using is very old and not supported anymore
you will need to be using the latest version for me to be able to fix this issue when you have auto scaling enabled
Hi Brian and thanks for your reply
You sent me this old version a few days ago to get me back up while I work on getting my Win 7 system back up (Re: Email – I give-up–Uncle). Fixing this old version isn’t that important. I was just trying tweak things in the meantime. Thought I missed a tick somewhere. Here’s the screen shot but you don’t need to waste your time on this issue.
Again ---- Thanks for your great application and service.
Screen Shot.doc (191 KB)
that screen shot, it looks OK for the windchill plot on the graph?
According to the NOAA Windchill Calculator that combination is zero, not below.
Sorry my bad —I meant to type 10 degrees not 18 — you are correct about that calculation, but at 10 degrees there is no capability to indicate a below zero reading. 10 degrees @ 25MPH calculates to minus 11F
Look at the new capture at the cursur location ---- Wind chill is negative 2.8 degrees but the graph is flat lined at Zero — also no scale left or right
Again Brian — this is not worth spending time on but just demonstrating my position on the matter.
Screen Shot.doc (192 KB)
