summary; icon overlap
I am getting 2-3 icons overlapping in the summary image:
http://gsfarm.ca/weather/summary.jpg
I have set webcam image as icon (cat or empty cat perch if cat not present). Is there a way to disable the other images so they don’t overlap (or position them to the side, up, or down?
Tnx!
-G.
you can customise the summary image
via setting the main screen customisation
and the moving things and then going back and saving
I suspect that has been done already has you do not have things in default locations
Yes I have set up the images, but I guess I messed something up.
you should be able to move the offending image to the right more (when its visible)
