Command not found when running sudo ./configure && make for libhid
That’s encouraging. I will continue with installing libusb and then if I have no luck, see if I can grab a working iso of someones server and use that instead.
EDIT
AFAIK libusb is installed already
sudo apt-get install libusb-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
libusb-dev is already the newest version (2:0.1.12-30).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Just to note. The “ConsoleWD for Raspberry Pi Setup Instructions” instructions at: HOWTO: ConsoleWD for Raspberry Pi Setup Instructions - Old version need to be updated as the url to obtain libusb is incorrect.
“libusb is a cross-platform user-mode library that provides access to USB devices. The project website is at libusb.info. The old project site libusb.org should not be used.”
Ok.
I’ve installed the image created by Peter (https://www.weather-watch.com/smf/index.php?action=profile;u=31636) and am still seeing the same issue.
Temp is reading correctly
Humidity is reading correctly
Windspeed is 0
Gustspeed is 0
Baromter is showing 1013.0
As before. All these sensors worked correctly on my Windows version of WD.
data read length ->50
 FF FF 30 60 00 00 0B 12 0D 01 12 00 CD 00 FF FF 00 46 E2 13 F6 03 34 02 FF FF 00 48 08 0C 0B B0 00 00 20 37 01 FF FF 00 42 00 BD 00 31 50 00 00 20 A0
send PC ready result 1
data read length ->15
 01 FF FF 00 42 C1 9A 00 5C 8C 00 00 20 A5 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
temperature found, sensor # 0
Temperature data found
Baro Data OK
Current data : Temperature= 14.4 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=92 Barometer=1013.0 Daily Rain=0.0
Just noticed. I’ve got an WMR180 not a 100.
I select the 100 in consolewd as that is what I select in the Windows version.
Is this perhaps the issue? The 180 isn’t actually supported in consolewd?
i wonder if there is data packets missing
i.e I might need to increase the time out
try setting in the config.txt
wmr200 data read delay=
default is 1000
try increasing that
(restart consolewd)
I’ve increased it to 5000 and then 15000 but still get the same issue.
wmr200 data read delay= 5000
 FF FF 30 60 00 00 2D 15 0D 01 12 00 F2 00 FF FF 00 46 E3 03 F7 03 26 02 FF FF 00 48 08 0C 1C C0 01 01 00 3A 01 FF FF 00 42 00 C0 00 30 50 00 00 20 A2
 01 FF FF 00 42 C1 2A 00 58 1E 00 00 20 C3 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Baro Data OK
Current data : Temperature= 3.2 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=88 Barometer=1013.0 Daily Rain=0.0
the barometer reading of 1013 is just the default reading
I will add some more debug code around the baro data that has come in (e.g the crc error check etc)
try
http://www.weather-display.com/downloadfiles/consolewdtest.zip
more debug info about the barometer data (just concentrating on one thing at a time )
That’s the new consolewd in place and this is what I’m seeing:
 01 FF FF 00 42 C1 29 00 59 1E 00 00 20 C3 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 baro crc sum 151 crc 451
Baro Data OK
Current data 23:16:46: Temperature= 3.1 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=89 Barometer=1013.0 Daily Rain=0.0
try another update
I’ve tested the new version and no difference in readings.
I do notice that it no longer says “Baro Data OK”
Also of note. the temp was showing as 3.5C before and after on Windows and on the base station. On the Pi it was showing as 2.5C
Here is the output.
Interesting that 1013 is the default value. I was wondering why it had this figure.
01 FF FF 00 42 C1 23 00 59 14 00 00 20 B3 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Current data 10:52:11: Temperature= 2.5 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=89 Barometer=1013.0 Daily Rain=0.0
**** doing minute routines now 10:52:11
**** updating clientraw extra files
**** updating data logs
there must be some differences with this station type compared to the wmr100 for the data output
which does not affect the windows version
but does affect consolewd
which is due to differences in the way it gets the data
i.e consolewd is looking for certain markers
what I will do is output all the raw data as it arrives
actually in checking my code, all the raw data that arrives is shown
e.g like
can you collate and post all that data that arrives?
I’ve uploaded the output from running consolewd for a while to my website:
http://digitalessence.net/weather/console-output.txt
thanks,
Hedley
OK I see the problem
the data other than temp/hum is arriving all at once, i.e all in the same data line
and so it needs to be split/teased out (the FF’s divde the data)
I will work on that and let you know
Sweet. That’s great news, thank you.
BTW, have you/anyone else written a doc on how WD works in terms of how it collects and parses the data? Would be interested to know what the process is and what the numbers mean.
try vers 14.0
That’s looking better. I’m now getting Windspeed, Gust and Direction coming in but the Windspeed and Gustspeed are the same.
Barometer is still showing 1013.0
And the temp data is still off.
On Windows and the weather base station it is showing as 0.5C but in consolewd it is showing as -0.5C. Pressure is showing as 1020 but WD shows it as the default 1013
I noticed a discrepancy in temps on the 14C as well.
Let me output it to a txt file for a few minutes and upload it again.
Current data 10:15:37: Temperature= -0.5 Windspeed =8.6 Gustspeed =8.6 Direction =270 Humidity=98 Barometer=1013.0 Daily Rain=0.0
 01 FF FF 00 42 C1 05 00 62 0A 00 00 20 94 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 01 FF FF 00 42 C1 05 00 62 0A 00 00 20 94 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 FF FF 00 42 C1 05 00 62 0A 00 00 20 94 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Current data 10:15:53: Temperature= -0.5 Windspeed =8.6 Gustspeed =8.6 Direction =270 Humidity=98 Barometer=1013.0 Daily Rain=0.0
the barometer data does not update very often
it should come in though
re the temperature, maybe you have set a temperature offset in the config.txt file
Good spot. The config I was using was the one supplied with the image and had a -1 in temp offset=
I have now removed this and the temp is correct.
So
  1. windspeed & gustspeed are still duplicated with the same value for both
  2. Will wait for the barometer to update until which time I assume it will sit at the default 1013.0 it has updated and is now showing the correct reading.
I’ve uploaded the output from running the most recent version of consolewd to my website:
thanks.
