Command not found when running sudo ./configure && make for libhid
Just to add.
I restarted consolewd and it stopped updating these files. Tried restarting several times and nothing.
I then edited my config.txt and removed the space between the equals sign and the values for Wunderground (I know, silly me) restarted and it started uploading to Wunderground! It also showed that it was updating the extra files.
151653 -rwxrwxrwx  1 pi   pi       5562 Jan  9 11:02 wdconsole.ini
151631 -rwxrwxrwx  1 pi   pi       3808 Jan  9 11:02 config.txt
151677 -rw-r--r--  1 root root      210 Jan  9 10:42 extravpdata.txt
151513 -rw-r--r--  1 root root     2564 Jan  9 10:42 clientrawextra.txt
151511 -rw-r--r--  1 root root     2092 Jan  9 10:42 clientrawhour.txt
151678 -rw-r--r--  1 root root      369 Jan  9 10:40 cronwudata.txt
151509 -rw-r--r--  1 root root      625 Jan  9 10:32 clientraw.txt
151679 -rw-r--r--  1 root root     1802 Jan  9 08:05 clientrawdaily.txt
Stopped and added FTP details to my server and restarted and now nothing again. Took out the FTP details I had just added and still nothing, no uploading to wunderground or updating of the client files.
Nothing else has changed and I’m back to
Data read length ->-1
send PC ready result 1
data read length ->-1
data read length ->50
 FF FF 30 60 00 00 00 0B 09 01 12 00 B7 00 FF FF 00 46 D7 13 EB 23 3E 02 FF FF 00 48 0B 0C 0E E0 00 00 10 5D 01 FF FF 10 42 00 A0 00 30 32 00 00 20 74
data read length ->1
Will continue to investigate.
This is what Wunderground shows: https://www.wunderground.com/personal-weather-station/dashboard?ID=ISCOTTIS5#history
Another update (sorry).
I reset the USB hub and as soon as I did I started to get different results in the console and things are looking up again.
**** doing minute routines now 11:25:01
**** updating clientraw extra files
**** updating data logs
updating wunderground
Sending WU data now
updating records to ini file
WU data to send http://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=ISCOTTIS5&PASSWORD=WU9bh73xa&dateutc=2018-01-09+11%3A26%3A01&winddir=000&windspeedmph=0&windgustmph=0&humidity=0&tempf=55.4&rainin=0.00&baromin=29.914&dewptf=122.0&weather=&clouds=&dailyrainin=0.00&solarradiation=0.0&UV=0.0&softwaretype=WeatherDisplay%3AWD_console_13.0&action=updateraw
Wunderground data send Ok 11:25:03
 FF FF 30 60 00 00 19 0B 09 01 12 00 D0 00 FF FF 00 46 D7 13 EB 23 3E 02 FF FF 00 48 0C 0C 0D D0 00 00 10 4D 01 FF FF 10 42 00 AC 00 2F 3C 00 00 20 89
Must leave it alone now… :wink:
But I can’t. So I edited the config file to enable FTP again and restarted consolewd and again it didn’t work.
Reset the hub/base station connection and it is working again. Seems I have an issue with consolewd not seeing the hub/base station if stopped and restarted.
Could this be because of the issue I had with ./configure && make for libhid or is it something else?
On further inspection I found that my station wasn’t reporting the current pressure to Wunderground correctly. I had a look using the parser at https://www.tnetweather.com/wdparserold/?p=wdparserold and it was showing an old out of date value.
My new outdoor temp/hygro sensor has arrived and upon restarting consolewd I see the same issue. It isn’t updating the .txt files.
I’ve pulled the usb hub from the Pi and put it back into my PC to test and everything is working correctly and I am updating to wunderground as well.
Interestingly, once I pulled the usb hub from the Pi I see this in my console:
USBWrite Write Erro Broken pipeUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWrite Write Erro No such deviceUSBWritsend PC ready result 19
So it can see the hub, knows when it isn’t connected, says it is getting data but either isn’t, or does but it is incorrect.
restarting consolewd shows:
Weather Display vers WD_console_13.0
If use this program,then please consider sending a PayPal donation to [email protected] (Brian Hamilton)
www.weather-display.com
Cannot connect to station: Device or resource busy
WMR100 opened OK
EDIT (again):
I revisited the sudo ./configure && make issue I was having and after a bit of googling I found that if I use
sh configure && make
It works.
So, now I have the following in my console:
Current data 16:21:06: Temperature= 1.7 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=79 Barometer=1013.0 Daily Rain=0.0
The temp and humidity are as expected as is the timestamp but the barometer is wrong. It should be around 1000. Also there is a wind blowing, not always but often enough that I would expect some wind to show.
My Weather Station is a WMR180 and I set it in the config file to type=232 which is as per the WMR100. I did this because in the Windows version the WMR180 selection was the same as the 100. Is this correct?
Also, if I run a lsusb it shows the station is reporting as a WMRS200.
pi@raspberrypi:~ $ lsusb
Bus 001 Device 004: ID 0fde:ca01 Oregon Scientific WMRS200 weather station
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I’m now at a loss. Anyone got any ideas? is there any further info i can provide that will help fault find?
Thanks again.
I would need to add some debug code re the barometer
When I get. Back tomorrow
Thank you very much. Although there is no hurry as I can run it fine on my Windows desktop, it’s just that I’m impatient when I get my teeth into something even if its taken months to start in the first place.
It looks as though it isn’t just the barometer that is wrong. The windspeed, Gustspeed and Direction were all showing as 0 but as soon as I plugged it back into Windows I started getting values for these. Rain will be 0 as I don’t have a sensor for that yet.
So Time, temp and humidity were correct.
Temperature= 1.7
Windspeed =0.0
Gustspeed =0.0
Direction =0
Humidity=79
Barometer=1013.0
Daily Rain=0.0
I am back now
so can work on adding some more debug code if you like
that would be great thanks.
I’ve tested again on the Pi and I am definitely not getting:
Windspeed
Gustspeed
Direction
as these are all 0 values.
And the Barometer reading is incorrect compared to what I see on the Windows version and the weather station base station.
The temperature and Humidity are correct
This is what I see in the console:
data read length ->15
 01 FF FF 00 42 C1 29 00 62 28 00 00 20 D6 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
temperature found, sensor # 0
Temperature data found
Baro Data OK
Current data 08:49:41: Temperature= 4.1 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=98 Barometer=1013.0 Daily Rain=0.0
**** doing minute routines now 08:50:03
cronftpreal: no process found
and this is the contents of my clientraw.txt file uploaded to my FTP server
12345 0.0 0.0 0 4.1 98 1013.0 0.0 0.0 0.0 0.000 0.000 0.0 0 0.0 3 0.0 0 0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0 0 0 08 51 40 Innerleithen-08:51:40 0 0 12 1 0 0 0 0 0 0 0 4.1 3.0 13.0 1.5 3 Dry 0.0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0.0 3.8 118.4 12/1/2018 10.8 -1.1 13.0 1.5 0.0 0 0 0 0 0 0 0 0 0 0 13.0 13.0 6.1 1.5 1.5 1.7 1.7 1.7 1.7 2.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 13.0 1.5 4.1 0.0 0 --- --- 0 0 0 0.0 0.0 0 0 0 0 0 0.0 18.3 0.0 3.2 1013.0 1013.0 0 00:00:00 00:00:00 12.0 -0.1 3.8 -1.9 0 2018 2018 -1 1 -1 0 0 0 0 0 0 0 0 0 0 0.0 0.0 0.0 4.0 0.0 0.0 0.0 98 78 !!CWD_console_13.0!!
I just wanted to point out that although you suggested I wouldn’t need to, I was able install libhid, but I haven’t installed libusb as per the Pi install instructions. I did though copy all the files from consolewdfiles/deploy to the systemfolders .
[i]1.3 install libusb
1.3.1 download from http://www.libusb.org/
1.3.2 in a terminal-window go into that folder and type
sudo ./configure --prefix=/usr --disable-static && make
at the end you will get an error 1, ignore those
sudo make install
this finishes without errors
            • this finishes the first step[/i]
If I can provide any further information please say. And I will of course be chucking a donation your way as this program is fab and I really appreciate your help.
it looks like for you, its not passing the CRC error checks, etc
you could try carrying on with installing and configuring libusb
it does work for others with a wmr100 (and it does work OK here too)
That’s encouraging. I will continue with installing libusb and then if I have no luck, see if I can grab a working iso of someones server and use that instead.
EDIT
AFAIK libusb is installed already
sudo apt-get install libusb-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
libusb-dev is already the newest version (2:0.1.12-30).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Just to note. The “ConsoleWD for Raspberry Pi Setup Instructions” instructions at: HOWTO: ConsoleWD for Raspberry Pi Setup Instructions - Old version need to be updated as the url to obtain libusb is incorrect.
“libusb is a cross-platform user-mode library that provides access to USB devices. The project website is at libusb.info. The old project site libusb.org should not be used.”
Ok.
I’ve installed the image created by Peter (https://www.weather-watch.com/smf/index.php?action=profile;u=31636) and am still seeing the same issue.
Temp is reading correctly
Humidity is reading correctly
Windspeed is 0
Gustspeed is 0
Baromter is showing 1013.0
As before. All these sensors worked correctly on my Windows version of WD.
 FF FF 30 60 00 00 0B 12 0D 01 12 00 CD 00 FF FF 00 46 E2 13 F6 03 34 02 FF FF 00 48 08 0C 0B B0 00 00 20 37 01 FF FF 00 42 00 BD 00 31 50 00 00 20 A0
 01 FF FF 00 42 C1 9A 00 5C 8C 00 00 20 A5 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Baro Data OK
Current data : Temperature= 14.4 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=92 Barometer=1013.0 Daily Rain=0.0
Just noticed. I’ve got an WMR180 not a 100.
I select the 100 in consolewd as that is what I select in the Windows version.
Is this perhaps the issue? The 180 isn’t actually supported in consolewd?
i wonder if there is data packets missing
i.e I might need to increase the time out
try setting in the config.txt
wmr200 data read delay=
default is 1000
try increasing that
(restart consolewd)
I’ve increased it to 5000 and then 15000 but still get the same issue.
wmr200 data read delay= 5000
 FF FF 30 60 00 00 2D 15 0D 01 12 00 F2 00 FF FF 00 46 E3 03 F7 03 26 02 FF FF 00 48 08 0C 1C C0 01 01 00 3A 01 FF FF 00 42 00 C0 00 30 50 00 00 20 A2
 01 FF FF 00 42 C1 2A 00 58 1E 00 00 20 C3 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Baro Data OK
Current data : Temperature= 3.2 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=88 Barometer=1013.0 Daily Rain=0.0
the barometer reading of 1013 is just the default reading
I will add some more debug code around the baro data that has come in (e.g the crc error check etc)
try
http://www.weather-display.com/downloadfiles/consolewdtest.zip
more debug info about the barometer data (just concentrating on one thing at a time )
That’s the new consolewd in place and this is what I’m seeing:
 01 FF FF 00 42 C1 29 00 59 1E 00 00 20 C3 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 baro crc sum 151 crc 451
Baro Data OK
Current data 23:16:46: Temperature= 3.1 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=89 Barometer=1013.0 Daily Rain=0.0
try another update
I’ve tested the new version and no difference in readings.
I do notice that it no longer says “Baro Data OK”
Also of note. the temp was showing as 3.5C before and after on Windows and on the base station. On the Pi it was showing as 2.5C
Here is the output.
Interesting that 1013 is the default value. I was wondering why it had this figure.
01 FF FF 00 42 C1 23 00 59 14 00 00 20 B3 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Current data 10:52:11: Temperature= 2.5 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=89 Barometer=1013.0 Daily Rain=0.0
**** doing minute routines now 10:52:11
there must be some differences with this station type compared to the wmr100 for the data output
which does not affect the windows version
but does affect consolewd
which is due to differences in the way it gets the data
i.e consolewd is looking for certain markers
what I will do is output all the raw data as it arrives
actually in checking my code, all the raw data that arrives is shown
e.g like
can you collate and post all that data that arrives?
