It ias ages since I installed my Davis Pro2 (using a USB Serial logger) and my configuration has since changed (moved from Cumulus to WD)
Just wanted to sanity check what I think I need to do. New PC is running Windows Server 2016 (sames as Win 10 for drivers etc).
- Install Weatherlink (6.03) onto new PC
- Install latest Silicon Labs CP210x Windows Drivers and set COM port details in Device Manager
- Move Davis Pro2/USB Data Logger across to new PC
- Check communication is OK in Weatherlink
- Follow FAQ on this site to move WD to a new PC
- Check WD is seeing Vantage 2
Is this correct?
Do I actually need Weatherlink (I never use it) or can WD talk directly to the Davis USB data logger through the CP210x drivers?
Any gotchas or bits I’m missing?
Thanks!
