WD ftp upload popup?
How do i hide the ftp pop up that uploads to your website? I also can’t get it to only update every 5 min it’s updating every min. Where is the setting at? it seems to be in more than one place.
tick to show in system tray
in the connections setup in the FTP/internet setup
Is show in system tray in the settings?
I have it set to 5 min but it’s doing it every 1 min. Is this the wrong place? See image
Thank you
you need to set that setting in the connections tab (as per my post)
Yes for the ftp pop up window. It still uploading every 1 min instead of 5 min.
After the FTP program runs have a look in ftplogfull.txt file in the wduisplay folder and that will show you what files are uploading. The webpage files may be uploading every 5 minutes but there may be something like a webcam image uploading once per minute?
you might have the customise internet and file creation setup in use?
(and so have ticked to use 1 minute uploads there)
