I have a Heathkit ID-5001 which I have been using with WD on windows 7 for some time.
I upgraded to the, 9th October 2017 10.37S Build 58, because I saw that it had something to do with the ID50, which I presume it is for the ID-5001. So far the data much more efficient.
The problem is, the solar has stopped working. I looked through everything to make sure all of the correct check boxes and settings are ok. Still no solar reading in the Solar Sensor Setup.
Also the “Reset station data daily” In the Weather Station Type Selection has stopped working.
Thank you in advance
looks like I had not added support for solar with the new updated routine
if you could see what shows under view, debug
for the raw data
and post here the part about solar data
Attached is what hope you are looking for.
Document.docx (137 KB)
for me , that document is empty
all you need to do is copy/paste into a post here on the forum
I had the same problem. …But after re-tick the box in the solar setting and rewrite the coordinate, now It’s working Good!
Inviato dal mio SM-N9005 utilizzando Tapatalk
Here’s the screenshot from that word doc:
Thanks for converting the file. It seem I can’t copy and paste with the debug.
If you are using Win 7 or later you can use the Snipping Tool to take screenshots that can be posted directly as attachments.
try a new update of WD
it should work now (as long as you have set that you have solar in the heathkit weather station type setup)
