Modified Rain Gauge
I need help.
I have a modified rain gauge. I have to fix rain offset.
I tried all the ways but did not work. I changed the percentage - nothing. I was entering a new tip value (0.2), but in log file always is 0.8 mm/tip. The new rain gauge has 4 times the size of the original. What exactly i have to do to correct tipping?
Thanks in advance.+
p.s.
Happy New Year.
you do not say which version etc
This is the latest version WD 10.37 Linux build 295, pws Irox/honeywell/TE923. OS Ubuntu 16.04. Maybe I’m doing something wrong?
that is the information that I needed to know
I will investigate
try a new update, should be OK re the modified rain gauge setting now
Hello!
Now works without any problem. :smiley:
When I put “1” into “rainfall Setup-Modified rain gauge new tip” Weather Display shows 1.4/tip
For “0.5” it is 0.7/tip. For my case it is 0.2/1.4.
I noticed that for Raspberrypi1 in config.txt not present “modified rainfall” option. Does this option work for Raspberrypi1 consolewd version? If not, is it possible?
I do have that for the raspberry pi 3 version of consolewd
Ok. Thanks
i.e so I could add that to the raspberry pi 1/2 version
After the last rainfall I noticed a log file error.
After another tipping of Rain Gauge, an error occurred in the summation of the log file 12018lg.txt. I apply the log file for a better explanation. The wrong values are colored in red. Generally, an incorrect value for precipitation is obtained. I use WD for console for Raspberri pi version “WD_console_14.0”. For modifieed rain gauge in config.txt I have entered 0.2856.
20 1 2018 15 1 03.1 82 00.3 1004.8 4.8 5.0 270 0.0 0.2 0.2 0.2 0.6 20 1 2018 15 2 03.0 82 00.3 1004.8 4.7 6.4 282 0.0 0.2 0.2 0.2 -0.1 20 1 2018 15 3 03.0 82 00.2 1004.8 4.7 7.0 292[color=red] 0.2 0.3 0.3[/color] - Summing error (0.2+0.3=0.3?) 20 1 2018 15 4 02.9 82 00.2 1004.9 4.6 7.0 292 0.0 0.3 0.3 0.3 -0.5 20 1 2018 15 5 02.9 82 00.1 1005.1 4.6 7.0 292 0.0 0.3 0.3 0.3 1.2 20 1 2018 15 6 02.9 82 00.1 1005.1 4.7 7.0 292 0.0 0.3 0.3 0.3 1.2 20 1 2018 15 7 02.9 82 00.1 1005.1 4.7 3.5 292 0.0 0.3 0.3 0.3 1.1 20 1 2018 15 8 02.8 82 00.1 1005.1 4.6 4.3 281 0.0 0.3 0.3 0.3 0.6 20 1 2018 15 9 02.8 82 00.0 1005.1 4.4 4.3 270 0.0 0.3 0.3 0.3 0.6 20 1 2018 15 10 02.8 82 00.0 1005.1 4.1 4.3 270 0.0 0.3 0.3 0.3 2.2 20 1 2018 15 11 02.8 82 00.0 1005.1 3.9 3.3 271 0.0 0.3 0.3 0.3 1.2 20 1 2018 15 12 02.8 82 00.0 1005.1 3.7 3.3 283 0.0 0.3 0.3 0.3 1.2 20 1 2018 15 13 02.8 82 00.0 1005.1 3.5 3.3 290 0.0 0.3 0.3 0.3 1.4 20 1 2018 15 14 02.7 82 -0.0 1005.1 3.3 3.3 278 0.0 0.3 0.3 0.3 1.4 20 1 2018 15 15 02.7 82 -0.1 1005.1 3.2 2.8 270 0.0 0.3 0.3 0.3 1.4 20 1 2018 15 16 02.7 82 -0.1 1005.1 2.9 3.7 270 0.2 0.5 0.5 O.K.(0.2+0.3=0.5) 20 1 2018 15 17 02.7 82 -0.1 1005.1 2.7 3.7 270 0.0 0.5 0.5 0.5 0.8 20 1 2018 15 18 02.7 82 -0.1 1005.1 2.6 3.7 270 0.0 0.5 0.5 0.5 1.1 20 1 2018 15 19 02.7 82 -0.1 1005.1 2.6 3.2 270 0.0 0.5 0.5 0.5 1.4 20 1 2018 15 20 02.7 82 -0.1 1005.1 2.5 3.2 270 0.0 0.5 0.5 0.5 1.4 20 1 2018 15 21 02.7 82 -0.1 1005.1 2.4 4.9 270 0.0 0.5 0.5 0.5 0.2 20 1 2018 15 22 02.7 82 -0.1 1005.1 2.6 4.9 270 0.0 0.5 0.5 0.5 0.2 20 1 2018 15 23 02.7 82 -0.1 1005.1 2.6 4.9 270 0.0 0.5 0.5 0.5 0.1 20 1 2018 15 24 02.6 82 -0.1 1005.1 2.7 4.9 282 0.0 0.5 0.5 0.5 1.5 20 1 2018 15 25 02.6 82 -0.2 1005.1 2.7 3.9 292 [color=red]0.2 0.6 0.6[/color] (0.2+0.5=0.6?)
