Sending Test Data works, but I keep getting notifications from Wunderground that the station has stopped sending data. Expect that this is user error, but I find myself trying the same things over again and it’s not working :?
At this point I don’t have Rapid Fire setup and was looking to have weather data sent every 10 minutes…
you need to set the main switch on (shift it to the right)
and also you will need to set the main internet switch on, under control panel, FTP/Internet setup/connections
Thanks, that seems to be working. To make sure I understand this correctly, and to assist others with setting up Wunderground, I’ve attached a PDF with the steps for setup. Please provide feedback as necessary.
