Clientraw #128 & #129.
Thanks for that! I must have missed it, as it is called inTemp in the parser I’m using, as opposed to indoor temp.
I’ll let you know when I’ve fixed that up, but it’ll be a little while, assignments galore for the next two weeks!
Thank you Yerrin.
PM when you get it done and absolutely no rush.
The rain graphs from my earlier post ??? did you purposely shift them around ???
Good luck with your assignments.
I think the rain gauges just got swapped around due to them stacking from the right instead of the left in this layout, I’ll check it out later on
My graphs say undefined
I just upgraded to WD94.
Trying to figure out if it is Yerren, WD or me.
Your graphs are showing fine at my end mate.
looks OK to me too
might have just been a temporary glitch with the data
Good spotting. Indeed the titles seem to have forgotten how to say “last”…
There was a missing entry in the dictionary file, I’ve fixed it now.
It’ll probably be a few hours before the update comes through.
-Yerren
Hi Yerren
No panic of course, but if you made changes, did you manage to make the change for the high low for indoor temp or correct the rain gauge order ??? if so then I can reactivate display high low, if not, all is good.
I’ve actually just been working on that this morning, and have also pushed that update to the server.
Feel free to enable the high/low for the indoor temperature now, and that way when the update comes through it’ll all be working.
-Yerren
Thank you Yerrin
I hope you have a great weekend.
Regards
Bruce
Hi Yerrin the hi-lo is working perfectly now so the changes have come through. The rain gauge changes havent come through but ill keep a lookout for it.
Again thank you for your good work on this setup.
Trivial suggestion: when selecting graphs the drop-down menu appears on the left of the default graph, a long way away from the Graphs button. Could we have it to the right?
Is there any way to add Dew Point to the page? That is a big deal here in the summer.
Seems like it wouldn’t be hard to implement. My only concern is that changing it now might feel a bit janky for existing users.
Does anyone else have an opinion? I’m happy to implement it given some sort of general agreement
-Yerren
I just had a test and it doesnt make it clunky for me to change from left to right. So I am all good with it.
If you make the change can you possibly look at the rain guages too still being the wrong way around…
Have a great day.
It’s on the to-do list
EDIT: it’s actually at the top of the todo list now!
cool. How ever you layout the page is good with me.
We are expecting 70F dew points again this weekend. Tough on Minnesotans…
For clarity:
How do I update my website’s code to the latest implementation of the evolving program?
Does it pull it in automatically? Is there something to ‘refresh’ the website to the latest version?
I’v forgotten what I did, if anything, the last time there was an update.
Thanks: Dale
As long as you’re using a normal version of the software it happens automatically.
We should be up to version 1.1.7.7 (in the bottom right), so if you see that on your site everything is good.
-Yerren
