Hi again Yerren. Again thank you for your prompt response.
The indoor temp does have a high low as it is enabled on my old WDL and is still working. In the interim, i will disable the high low but someday if you do get to look at it that would be much appreciated.
Thanks for that! I must have missed it, as it is called inTemp in the parser I’m using, as opposed to indoor temp.
I’ll let you know when I’ve fixed that up, but it’ll be a little while, assignments galore for the next two weeks!
No panic of course, but if you made changes, did you manage to make the change for the high low for indoor temp or correct the rain gauge order ??? if so then I can reactivate display high low, if not, all is good.
I’ve actually just been working on that this morning, and have also pushed that update to the server.
Feel free to enable the high/low for the indoor temperature now, and that way when the update comes through it’ll all be working.
Hi Yerrin the hi-lo is working perfectly now so the changes have come through. The rain gauge changes havent come through but ill keep a lookout for it.
Trivial suggestion: when selecting graphs the drop-down menu appears on the left of the default graph, a long way away from the Graphs button. Could we have it to the right?
Seems like it wouldn’t be hard to implement. My only concern is that changing it now might feel a bit janky for existing users.
Does anyone else have an opinion? I’m happy to implement it given some sort of general agreement
