thank you so much!
using your changes second temperature shows +255 max and 100 min
Changing “input 2” to “input 1” in config.js:
temperature02: {
enabled: true,
title: “Secondo Sensore”,
input: 1
in fact, in globals.js it refers to “input 1”:
//Widget Config / Settings
var widgetList = {
apparent: {enabled: true},
temperature: {enabled: true, title: “default”, highLowEnabled: true},
temperature02: {enabled: true, title: “default”, highLowEnabled: true, input: 1}, //input: extra sensor 1
temperature03: {enabled: true, title: “default”, highLowEnabled: true, input: 2}, //input: extra sensor 1
using these settings, it seems to work fine at moment
as you can see: http://www.estensemeteo.com/
