Oh, no, what happened? They’re not loading any more. Or am I the only one with the problem?
What’s not loading any more? If you mean your FreshWDL it’s working fine for me :?
Oops, I complained too soon. Mine has returned to loading now. http://stillwaterweather.com/stwlive.html
That’s a good one :thumbright:
Hello.
This might be related to my post here: http://discourse.weather-watch.com/t/65971 but my rainfall graph has got confused/not showing all rain data.
It has rained most days over the last week but this no longer shows.
See here: http://217.199.187.197/otronics.co.uk/Weather/FreshWDL/FreshWDLmaster.html
Any ideas or is this a Weather Display problem itself?
Ignore - this must be a WD error. I’ve got into my old Weather Display Live data page and it’s doing the same thing.
we have had lots of rain here recently
which shows OK for me for my FreshWDL:
http://www.weather-display.com/windy/FreshWDLmaster.html
OK had a look at this and I likee. However, can I resize it so I can incorporate it into the framework of my existing website?
Lots of people seem to have had luck doing this using and iFrame.
I haven’t done it personally, but it seems to have worked for others
OK I have a question.
I have applied an offset for the windspeeds on my station (adjusted for height using the Met Office calculation) but Fresh WDL seems to be using the original speed not the adjusted speed, what can I do to force FreshWDL to use the adjusted speeds?
did you apply that offset in WD or on the actual station itself? (its not very clear)
In WD. However, I think I have solved the mystery. What caused me to doubt my readings was a quick glance at the Met Office page for my location that was showing windspeeds way above what I’m getting. It would appear that their website, whilst stating that windspeeds are in mph are actually showing windspeeds in kmh!! When you calculate what they’re displaying in mph it’s similar to mine (I’ve also been able to double check this with the weather station at the local airport so it’s definitely them not me lol).
Hi all!
freshwdl works fine, great job.
I would to know if it’s possible to insert second temp sensor
thanks
Sergio
my freshwdl:
http://www.estensemeteo.com/
Hey, to add another temperature sensor, do the following:
FreshWDLmaster.html changes:
On line 7: Change stylesheet01.css to stylesheet02.css
On line 16: Change InnerContent.js to InnerContent-02.js
Config.js changes:
Change the gaugeSettings field so it matches the following:
gaugeSettings = { //Gauges: apparent temperature barometer windChill graphHandlerBarometer graphHandlerRainfall graphHandlerTemperature graphHandlerWindSpeed humidity moonSun solar status rainfallTitle rainfallDay rainfallMonth rainfallYear UV windDirection windSpeed
solar: {
enabled: false
UV: {
enabled: false
windChill: {
mode: “windchill”, //The default mode, either “heatIndex” or “windchill” (note: lowercase c)
autoSwitch: true //If true, will switch between heat index/wind chill depending on what is appropriate.
temperature: {
title: " default "
temperature02: {
enabled: true,
title: “default”,
input: 2
temperature03: {
enabled: true,
title: “default”,
input: 3
You can change the title of each of the temperature sensors by adjusting the title field. So, for example, if you wanted to change the title of one of them to be Other Temperature, you
Works here for extratemp1, but my UV has been pushed to one side. . .
I note your instructions have solar and UV disabled. . . that’s no good to me. (But I only have UV )
Also, my temperature02 (Garden = extratemp1) needs “input: 1”
Currently that is going to be a bit of an issue. It might seem strange, but it’s actually quite a pain to move the gauges around. So even though there’s an obvious spot to put the UV, it’s no small job to get it there :lol:
I’ll add it to the todo list, but it will probably be a couple months before I have time to adjust it (apologies, life is very busy for me at the moment!)
Unfortunately for the time being you may have to chose between the extra temperatures and UV
thank you so much!
using your changes second temperature shows +255 max and 100 min
Changing “input 2” to “input 1” in config.js:
temperature02: {
enabled: true,
title: “Secondo Sensore”,
input: 1
in fact, in globals.js it refers to “input 1”:
//Widget Config / Settings
var widgetList = {
apparent: {enabled: true},
temperature: {enabled: true, title: “default”, highLowEnabled: true},
temperature02: {enabled: true, title: “default”, highLowEnabled: true, input: 1}, //input: extra sensor 1
temperature03: {enabled: true, title: “default”, highLowEnabled: true, input: 2}, //input: extra sensor 1
using these settings, it seems to work fine at moment
as you can see: http://www.estensemeteo.com/
Hi!
sorry for my English :oops:
changing temp3 with solar or uv it’s seems better
what do you think about it?
Sergio
