Thanks that helped. I am able to scale it down. In the Saratoga templates there is a user selectable option for ‘wide’ or ‘narrow’ display. I was able to auto adjust for that like this:
<div id="main-copy">
<h1><?php langtrans('Fresh Weather Display Live'); ?></h1>
<?php
if($_SESSION['CSSwidescreen'] == 1) { ?>
<object data="FreshWDLmaster.html" width="1200" height="600" background="white"> <embed src="FreshWDLmaster.html" background="white"> </embed> Error: Embedded data could not be displayed. </object>
<?php
;} else { ?>
<object data="FreshWDLmaster.html" width="650" height="375" background="white"> <embed src="FreshWDLmaster.html" background="white"> </embed> Error: Embedded data could not be displayed. </object>
<?php
</div><!-- end main-copy -->
Not sure if its me or not, but today is the first day where we are getting nice warm temps and with the windchill and heat index gauge in auto mode, the heat index is not showing any different from the main temperature gauge. There is wind here which I would have thought that the heat index would show a diff temp to the main temp gauge ???
You can just add a bgcolor tag to the html page code, or a background tag if you want a background image.
Bunty’s page with a colored background, note the added ‘bgcolor=“#FFB6C1”’
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns='http://www.w3.org/1999/xhtml' lang="en">
<head>
<!-- Include initially needed CSS -->
<link rel="stylesheet" type="text/css" href="https://gitcdn.xyz/cdn/Yerren/FreshWDL/master/css/stylesheet01.css" /> <!--Includes the project's css sheet -->
<link href="https://cdnjs.cloudflare.com/ajax/libs/opentip/2.4.6/css/opentip.css" rel="stylesheet" type="text/css" /> <!--Includes the tooltip's css sheet -->
<!-- Modal code must be outside of body so it can be referenced-->
<script type="text/javascript" src="https://gitcdn.xyz/cdn/Yerren/FreshWDL/master/UpperContent.js"></script>
<meta http-equiv="Content-Script-Type" content="javascript" />
<meta http-equiv="content-type" content="text/html; charset=UTF-8"/>
<title>Stillwater Weather Live</title>
</head>
<body bgcolor="#FFB6C1"
onload='initAll();'> <!--Once the page is loaded, start the initialization functions -->
<script type="text/javascript" src="https://gitcdn.xyz/cdn/Yerren/FreshWDL/master/InnerContent.js"></script>
<!-- Loading Screen Setup -->
<div id="loadingScreen">
<div id="loadingText">
<p id="titleText">Stillwater Weather Live</p>
<p id="loadingMessage">Collecting Data.</p>
</div>
</div>
<!-- First script that must be loaded -->
<script type="text/javascript" src="https://gitcdn.xyz/cdn/Yerren/FreshWDL/master/js_bundles/Loading.js"></script>
<!-- Include remiaing Scripts -->
<script type="text/javascript" src="config.js"></script> <!--Includes the local script that sets customisable variables-->
<script type="text/javascript" src="https://code.createjs.com/easeljs-0.8.2.min.js"></script> <!--Includes the drawing part of CreateJS: EaselJS-->
<script type="text/javascript" src="https://code.createjs.com/tweenjs-0.6.2.min.js"></script> <!--Includes the animation part of CreateJS: TweenJS-->
<script type="text/javascript" src="https://cdnjs.cloudflare.com/ajax/libs/opentip/2.4.6/downloads/opentip-native.js"></script> <!--Includes the tooltip library: OpenTip-->
<script type="text/javascript" src="https://gitcdn.xyz/cdn/Yerren/FreshWDL/master/js_bundles/moment-with-locales.min.js"></script>
<script type="text/javascript" src="https://cdnjs.cloudflare.com/ajax/libs/Chart.js/2.7.1/Chart.min.js"></script>
<script type="text/javascript" src="https://gitcdn.xyz/cdn/Yerren/FreshWDL/master/js_bundles/Globals.js"></script> <!--Includes the script that sets global variables-->
<script type="text/javascript" src="https://gitcdn.xyz/cdn/Yerren/FreshWDL/master/js_bundles/WidgetsHandlers.min.js"></script> <!--Includes most of the Scripting-->
</body>
</html>
Nico, (and others who program a lot):
You indicated a color value with the hex code. Is there a better way that guess and try, in other words is there a tool that shows the color spectrum and you slide the cursor around to generate the color code you need? Sort of what is like in the Color Setup in WD, which just returns the color and I think degree of hue? I’m looking for something that allows easy setting by showing me the color code in hex for the color I’m pointing at.
Since you seem well versed in this, I am taking the chance that you’ve seen such a tool. So far, my google guess as to key words hasn’t been helpful.
Thanks for any leads. Dale
I like this one which has been around on various sites for ever - note it refers to Netscape :lol:
Google for “color picker”, there’s a ton of them out there. Some will give you a palette of compatible colors, some are desktop apps that allow you to mouse over an image or website and get color codes of objects, there’s even a Chrome plugin to do that (but it’s a bit clunky IMHO).
