Depending on what HTML file you are using currently, it might take a bit for those changes to come through (due to a mistake in the script files I uploaded during the update) it should come right in a few hours or so
GrantK mine was the same as you the numbers were still not right so i pressed Ctrl and clicked refresh page in browser and it came right.
Should be all up and running fine now
Thanks Huggy. I tried that earlier without success but have just done it again and problem solved
Many thanks Yerren, all good now
All good, working now.
:greenjumpers: IE11 :thumbright:
Great stuff! I think a donation is in order. . .
My solar has a place for a bar but no color.
Do I need to change something?
Have you thought about changing the wind to a dial/speedometer style?
Currently the solar bar is percentage based. Turns out, most people can’t get that reading… So it’s not something on your end, it’s on mine! Both these issues are on the list
Much appreciated!
All is up and running.
Very easy setup
http://www.weather.kopaida.club/uploadWD/FreshWDLmaster.html
Thanks Yerren
Glad to hear it
Yerren, just to let you know. I tried WDL on my old Amazon Kindle Fire using the Silk browser and it works great. Good job!
Nice, that’s pretty awesome to hear!
Not sure if this has been mentioned but I’d like the option to turn off the forecast text shown from WD as I dont use that forecast on my site. I use WXSim for my forecasting. Adding the latest WXSim forecast would be problematic so just for me the option to remove the text would be good.
Something weird at my place:
I have FreshWDL showing just fine on my Win 7 laptop under the Mozilla Firefox display.
I went to three other computers I have, running anything from Win 10 with autoupdates and Mozilla, Chrome and IE on it, down to Win 7 with similar browsers, and an old XP with an old version of Firefox on it.
On those manchines I get the Splash screens, and the getting data message, with the little marching dots at the end, but never get any change to the dynamic real time display.
Anyone else had this going on? It all seemed to start after I uploaded the cofig and .html files about a week ago.
I can see if I’d goofed it up and nothing loaded, but why run on one computer and none of the others, no matter what browser I use. I’d think that the virus software wouldn’t prevent the data from loading, and it’s the same on all the computers, ZoneAlarm.
cant help much with out knowing the URL
Dale my guess would be that the path for the clientraw files in the config file is wrong.
I think Stuart might be right, and that the clientraw path is wrong in the config file. The reason it still works on your other browser is probably that the old config file is still cached. (If you press ctrl + F5) it will clear the cache, and probably stop working
To make sure the cache is cleared for all users after you are finished updating the config file, you can add a “version number” to the end of the script URL, as shown in this screenshot: https://puu.sh/z6Ffm/00c82643c4.png (so add ?v=x.x). Once you are happy with the changes to the config file, increase the version number and it will force all browsers to get the new config file.
(These instructions will be added to the future HTML file as well, just fyi)
Hope that helps! Let me know if the issue persists, and if you give a link to your site I’ll check it out in more detail.
