Author Topic: JavaScript WDL version 1.0.0 alpha.  (Read 35247 times)
Offline Yerren
  • FreshWDL developer
  • New Zealand
  • Win NT 10.0
  • Firefox 66.0
    • The current JavaScript WDL build
Re: JavaScript WDL version 1.0.0 alpha.
« Reply #495 on: March 20, 2019, 06:56:11 PM »
Thank you Yerrin your a gentleman and a scholar...............just one small issue, the min - max for the indoor is showing between 0 and 1 .........have i done something else wrong.
And also, are you aware the rain gauges changed, now it is the yearly rainfall gauge that is first rather than the daily rainfall gauge i.e they changed order from daily, monthly, yearly to yearly monthly, daily
Regards
Bruce
You're very welcome :)
From memory, the indoor temperature doesn't have high/low data records for whatever reason.
To deal with this, you can disable them for that gauge, by using: highLowEnabled: false. So your whole config for that gauge looks something like:
Code: [Select]
temperature02: {
            enabled: true,
            title: "Indoor Temperature",
            input: "indoor",
Offline huggy
  • Dunedin New Zealand
  • Win NT 10.0
  • Chrome 72.0.3626.121
    • Fairfield Dunedin Weather Report
« Reply #496 on: March 20, 2019, 10:26:20 PM »
Hi again Yerren. Again thank you for your prompt response.
The indoor temp does have a high low as it is enabled on my old WDL and is still working. In the interim, i will disable the high low but someday if you do get to look at it that would be much appreciated.
http://www.fairfieldweather.info/old.html
Offline bitsostring
  • Oregon Scientific WMR200
  • Edinburgh, U.K.
  • Win NT 10.0
  • Chrome 64.0.3282.140
    • Home Weather Station
« Reply #497 on: March 20, 2019, 10:31:39 PM »
Clientraw #128 & #129.
It's meant to be fun. . .
Offline Yerren
  • New Zealand
  • Win NT 10.0
  • Firefox 66.0
« Reply #498 on: March 20, 2019, 10:56:58 PM »
Thanks for that! I must have missed it, as it is called inTemp in the parser I'm using, as opposed to indoor temp.
I'll let you know when I've fixed that up, but it'll be a little while, assignments galore for the next two weeks!
Offline huggy
  • Win NT 10.0
« Reply #499 on: March 20, 2019, 11:12:24 PM »
Thank you Yerrin.
PM when you get it done and absolutely no rush.
The rain graphs from my earlier post ???? did you purposely shift them around ??????
Good luck with your assignments.
Offline Yerren
  • New Zealand
  • Win NT 10.0
  • Firefox 66.0
« Reply #500 on: March 21, 2019, 02:34:49 AM »
Thank you Yerrin.
I think the rain gauges just got swapped around due to them stacking from the right instead of the left in this layout, I'll check it out later on :)
Offline chief-david
  • Win NT 10.0
  • Chrome 73.0.3683.103
    • Robbinsdale Middle School Weather
« Reply #501 on: May 02, 2019, 10:22:40 PM »
My graphs say  undefined
I just upgraded to WD94.
Trying to figure out if it is  Yerren, WD or me.
https://rms-weather.rdale.org/weather.php
Vantage Pro Plus 6163
KMNMINNE28
CWOP DW6947
Midwesternweather.net
twitter @RMSWeather
Offline huggy
  • Win NT 10.0
  • Chrome 74.0.3729.131
« Reply #502 on: May 02, 2019, 10:30:46 PM »
Your graphs are showing fine at my end mate.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #503 on: May 02, 2019, 10:38:34 PM »
looks OK to me too
might have just been a temporary glitch with the data
Offline Yerren
  • New Zealand
  • Win NT 10.0
  • Firefox 66.0
« Reply #504 on: May 02, 2019, 10:47:17 PM »
Good spotting. Indeed the titles seem to have forgotten how to say "last"...
There was a missing entry in the dictionary file, I've fixed it now.
It'll probably be a few hours before the update comes through.
-Yerren
Offline huggy
  • Win NT 10.0
« Reply #505 on: May 02, 2019, 11:09:41 PM »
Hi Yerren
No panic of course, but if you made changes, did you manage to make the change for the high low for indoor temp or correct the rain gauge order ????? if so then I can reactivate display high low, if not, all is good.
Offline Yerren
  • New Zealand
  • Win NT 10.0
  • Firefox 66.0
« Reply #506 on: May 02, 2019, 11:45:15 PM »
Hi Yerren
I've actually just been working on that this morning, and have also pushed that update to the server.
Feel free to enable the high/low for the indoor temperature now, and that way when the update comes through it'll all be working.
-Yerren
Offline huggy
  • Win NT 10.0
« Reply #507 on: May 02, 2019, 11:50:12 PM »
Thank you Yerrin
I hope you have a great weekend.
Regards
Bruce
Offline huggy
  • Win NT 10.0
« Reply #508 on: May 03, 2019, 02:26:21 AM »
Hi Yerrin the hi-lo is working perfectly now so the changes have come through. The rain gauge changes havent come through but ill keep a lookout for it.
Again thank you for your good work on this setup.
Offline bitsostring
  • Edinburgh, U.K.
  • Win NT 10.0
  • Chrome 70.0.3538.102
« Reply #509 on: July 10, 2019, 09:29:20 PM »
Trivial suggestion: when selecting graphs the drop-down menu appears on the left of the default graph, a long way away from the Graphs button. Could we have it to the right?
