I have been neglecting my web site for a while and noticed that I am seeing a message “last updated October 21 2017”. The temp and some other variables are correct, but the rain and high and low temps are from oct 21st. I guess my brain is not remembering how I did this back awhile ago.
I’m hoping someone could point me in the right direction.
I did not find a recent or installed Leuven-Template site.
Just http://www.frontrangeweather.net/weather28/ which is using WeatherCat, incompletely installed and has data from the original download, not from a real weather-station.
QUESTION: What is the URL to the site with the Oct 21 data and what weather-program is used?
The WIKI describes the uploads at: en:upload [Leuven-Template 2.8]
Scroll to the bottom at that page and you can select description for the weather-program you are using
The realtime data comes from clientraw and is uploaded Ok and the contents is OK
The 5 minute data is not uploaded by WD since Oct 21.
What you should check. 1. Restart WD
Restart WD and wait 10 minutes if uploading starts normally 2. If not check the settings in WD.
The WiKi explains it (more or less) https://leuven-template.eu/dokuwiki28/doku.php?id=en:uploadwd
As it worked in the past you have to compare the bottom part of that WiKi page with your WD screens. I already attached a screenshot from that page here.
This empty upload occurs when WD has no file to process in its “to-process folder”.
This WD folder is most of the times located at C:\wdisplay\webfiles\ but its exact location depends on your install decisions.
I think the file in C:\wdisplay\webfiles\tags.wd.txt has been over written with the converted version so no tags in it so will need a fresh copy as Wim has said
