WXSIM and the import of station data
Greetings to all
1 month ago, I started having problems on my PC, with Windows7. Since the problems worsened, I decided to start from scratch.
I took the opportunity to change the PC and, now, the operating system is Windows10.
I have had a lot of difficulties in reinstalling programs that I had in the old PC, but, little by little, everything is normalizing.
Thanks to the invaluable help of Tom Ehrensperger, WXSIM, WXSIMATE and WRET are working perfectly.
The only problem (minor) that I have not yet been able to request, is the following:
  • WXSIMATE downloads all the data correctly.
  • WXSIM works well, but stops when trying to import the data from the station (attached images).
I have come to think that maybe it is a problem in the treatment of hours.
WXSIMATE configuration:
- Local station source: Weatherlink
- Units for display here:
Temperature: Celsius
Pressure milibars (hPa)
Wind Speed: km / kr
Precipitation: mm
- Archived data time settings:
Use 0 minutes before hour (best in much of world)
Station data is end of archive interval
- Smoothing:
Precipitation: 30minutes
Wind Speed: 20 minutes
Wind direction: 20 minutes
Cloud cover: 60 minutes
- Scheduler:
3:00 A.M
8 AM
3 PM
8 PM
Download at 8 minutes past the hour
WXSIM configuration:
- Stability Indices: NW European
- Date Format: Da / Mo / Yr
- Time format: GMT (Z)
- Solar Energy Units: Watt * hours per m2
- Planner Thickness Scale: 400 m range
v Show Convective Bulletins
v Bar Graph Precipitation
v Use Anthropogenic and Solar Forcing
- Output Menu:
4 wind direction, wind chill factor …
- Auto Run and other Settings:
  • Auto Run at:
    3:00 A.M
    8 AM
    3 PM
    8 PM
    10 minutes after hour
  • Settings for before and during run:
    -Import data before run
  • Import advection data before run
    v Use GFS for initial advection
    v Enforce monotone fit
  • Use MOS / GFS advection on wind shits
  • Use curvature search for advection
  • Use soil calculation (pto mode only)
