Out of curiosity I was at the VIS website and noticed that the latest version of VIS reader is: 3.7.9.1 and the version in Weather Display is: 3.5.9.92
Does WD update the latest VIS reader with it’s program updates…?
Does it even make a difference being a couple versions of VIS off??
I have the latest WD program update…
I can only assume that the VIS reader is only needed to capture the data for weather display. In my experience VIS reader updates add features and functionality to the UI. Those features can be pretty neat if you are using the reader as your interface to the data or, if it is the main software for your set-up. For instance, one recent update includes fire weather information.
its not needed to be using the latest VIS reader if the version you have works OK
I provided the code for VIS reader, as the author said he would help me improve it
now he has taken that code and run with it and is trying to create an all round weather station software
