Weather34 V3.4-X5(d) problem - SORTED
Just discovered that the max-mintemp.php module for the top row doesn’t work for negative
bitsostring,
Unfortunately Brian Underdown has discontinued supporting the weather display version of this script so he won’t be able to help. I assume that the max and min figures are taken from clientraw via the livedata.php script. I would have a look in their to see if that shows any issues. After that I would look at temperature.php which is the script used to produce the figures in the temperature module. I unfortunately don’t use that version anymore, so can’t help much.
Paul
Thanks, Paul
Finally got round to looking at max-mintemp.php and discovered that only temps >0 (
