climatedataoutmyyyy.html
How do you create and upload the climatedataoutmyyyy.html file? I’ve set File #41 to create/upload files but I’m not sure this is where they are created. In any case nothing happens. The last files I have in the webfiles directory and on the actual website were created in July 2016. Recreating under averages/extremes doesn’t make these files either. I’m trying to get my snow graphs working and believe this is the file that is missing.
Rick
see under view, av/ext, uploads
That button is selected on. Has been for years. The climatedataoutmyyyy.html file never gets created.
it works great here
maybe if you could post some screen shots of your settings
Is this what you are looking for?
yes
try also ticking to upload the standard noaa report
I presume WD is runnning all the time?
also is there a
climatedataoutlocal.html file in the WD web files folder?
No luck with the climatedataoutmyyyy.html file creation. Also there is no file climatedataoutlocal but there is a climatedataout.html.
you need to have a climatedataoutlocal.html file
that is the template file
what version/build of WD etc?
