basic requirements for an IP web cam?
I am interested in setting up a webcam, and due to distance constraints, it needs to be an IP camera.
I have tried connecting the Web Cam Capture program to my D-Link DCS5222L camera as an experiment, but it won’t connect. Should it ?
What are the basic requirements for a web cam to work with WD? (forgetting image quality, weatherproofing and all that stuff - just the basic interfacing that makes it connect)
I have added more info on how the URL should look like for an IP cam this this update
http://www.weather-display.com/downloadfiles/wdwebcamcapture.zip
which has a new option to use a cron program you could try to get the image
thanks - I got the D-Link connected to wdwebcamcapture - now to work out what I want to do, and how to do it :smiley:
so you got it working with that new version?
great
did you use the separate cron method, or?
I just used the wdwebcamcapture program. I’m not sure what the pros and cons are between the 2 methods (and also unsure how I’m going to integrate the pictures with my website yet)
just to be clear, you used the new version from the link above?
yes, I did
and the picture is updating OK?
yep, seems to be doing fine (although my test camera just looks at cars in the garage - so not a lot of action ! :D)
Its just that someone else reported it would not update
But good it is for you
I was using WDwebcamcapture (latest version) for several hours today to take snapshots from my Ubiquiti camera and save them to a file. It worked flawlessly for the simple task I was doing.
WDwebcamcapture is a very capable program which does far more than I need, so have now replaced it with a Cron task on my Linux box.
