kocher
8 December 2017 11:55
1
Following a PC change, I have problems with the “clientraw.txt ” file:
http://kocher.es/clientraw.txt
It does not appear locally: C\wdisplay\webfiles\
It does not appear on the server: http://kocher.es/clientraw.txt
There is a file (that is updated), called: “clientrawtemp.txt”
http://kocher.es/cajon/clientraw1.png
http://kocher.es/cajon/clientraw2.png
WeatherDisplay Ver 10.37S60
Uncheck the box for “Rename the file as a temporary file (Recommended if your server supports that)”. Your Microsoft IIS server does not support it.
kocher
8 December 2017 17:43
3
Thank you very much for the reply Niko
The file “clientraw.tx t” continues without being created.
I have come to think that it may be influenced by the antivirus program I just installed (Bitdefender)
http://kocher.es/cajon/clientraw3.png
http://kocher.es/cajon/clientraw4.png
http://kocher.es/cajon/ftplogfull.txt
windy2
8 December 2017 17:45
4
do you mean its not being created locally?
kocher
8 December 2017 17:48
5
Greetings Brian
It has not been created locally or uploaded to the web
windy2
8 December 2017 18:02
6
well it wont get uploaded if it does not get created localy
is WD getting live data from your weather station?
try re selecting the clientraw location in the webfiles setup
windy2
8 December 2017 18:03
7
also I see you have ticked to create a 2nd clientraw.txt but in the same location
untick that
kocher
8 December 2017 18:12
8
Okay, I just unchecked it
I discovered that if I create a file called “clientraw.txt” and try to paste it into c:\wdisplay\webfiles\ , a Windows 10 message appears:
Denied access to the folder.
You will need Administrator permissions to copy to this folder
http://kocher.es/cajon/clientraw5.png
([color=blue]I'm running WeatherDsiplay as Administrato[/color]r)
windy2
8 December 2017 18:15
9
that is likely your problem
a problem with permissions under windows 10 on that folder
you will need to fix that
kocher
8 December 2017 19:02
10
Problem solved.
I explain it in case it happens to any other:
Source of the problem : Security Policy Windows 10
Windows 10 does not allow certain actions, even if the user has Administrator privileges , in case of initiating the session without a password.
Many thanks to Niko and Bria n for their invaluable help
