When I hold/move the cursor over the wind/barometer graph (top one see upload) the time & data change the same happens on the wind direction graph, but the time/data does not alter when I hold/ mouse cursor on the temp/dew point etc. on the bottom graph, my question is should it or did it ever do that ? I’m sure it did alter the same as the wind/wind direction graphs do, but I could be wrong.
Using W10 & Wd 10.37S61.
Just went back to build S58 & the graph time/temp is working OK. I checked to see if I had to plot freezing line & it was not ticked, also tried ticking it but it made no difference, so I will carry on with build S58.
This problem has come back, now using build 62 (26/12/17). It works ok for a while but then stops again. I just on my way out now so I will have a look latter when I get back.
