try this test program
http://www.weather-display.com/downloadfiles/cronlazersnow.zip
to see if the raw data flows
Thanks, I’ll try this evening.
Tom
It finds it but no data flow.
Devices found 0417 DD03
Lazer snow connected 0417 DD03
Using lrtimelog.exe to read the sensor on win8.1
I will need to use a different HID USB component then by the looks
I will then hold off until your next version is released…Thanks.
I need to know the hex value of the PID and VID using windows device manager
I do not know how to find the hex value of the PID and VID using windows device manager.
I apologize for my ignorance.
Also please be aware something has changed in your website’s security certificate.
The connection warning I received is attached and it is occurring no matter where I log in and despite using multiple platforms.
yes, I know about the forum certificate error
I am not the forum admin, so I can not help with that, sorry
re vid/pid hex
simply run windows device manager, then see the usb/hid devices, find your device (the lazer sensor) and it should show the vid/hid values there (properties)
I am including two devices as supposedly the Fluke 414D may be recognized as a keyboard in the Dallas1wire…I am not certain I am giving you the correct devices.
Found under HID device:
Device HID\VID_0417&PID_DD03&MI_00\9&14cb3d3&0&0000 was configured.
Driver Name: input.inf
Class Guid: {745A17A0-74D3-11D0-B6FE-00A0C90F57DA}
Driver Date: 06/21/2006
Driver Version: 10.0.14393.82
Driver Provider: Microsoft
Driver Section: HID_Raw_Inst.NT
Driver Rank: 0xFF1004
Matching Device Id: HID_DEVICE_UPR:FF00-FFFF
Outranked Drivers: input.inf:HID_DEVICE:00FF1005
Device Updated: false
Parent Device: USB\VID_0417&PID_DD03&MI_00\8&27c7df8b&0&0000
Found under Keyboard:
Device HID\VID_0417&PID_DD03&MI_01\9&280bb056&0&0000 was configured.
Driver Name: keyboard.inf
Class Guid: {4D36E96B-E325-11CE-BFC1-08002BE10318}
Driver Version: 10.0.14393.0
Driver Section: HID_Keyboard_Inst.NT
Driver Rank: 0xFF1003
Matching Device Id: HID_DEVICE_SYSTEM_KEYBOARD
Parent Device: USB\VID_0417&PID_DD03&MI_01\8&27c7df8b&0&0001
I took photos of the Device Manager window before and after unplugging the Fluke 414D (with the TrippLite active USB cable extension)
See before (9099) and after (9100) photos if that helps
see my message above about a new test version to test
No logging is taking place in the chronlazersnow app window
This may be an issue of me sending the incorrect device info…but thanks so much for your patience and trying
you have sent the correct info
does it say connected?
it might be that I need to send a command to get it to log
it might be that you need to run the software that comes with it at the same time
(try doing that with the dallas1wirereader program)
Bad news…
The LR Demo Program runs but there’s no data being measured…even after a complete system restart & unplug/plug USB
Cron Lazer Snow shows nothing…
UPDATE:
I got my usual setup going again…give me a few minutes to try the cron program again
Cronlazersnow still is not logging or sending any message regarding connecting…by the way in the US laser is with an “s” not “z”
Thanks for your efforts
Would downloading the free LRSimple program from porcupinelabs.com …that I can verify is logging… help you?
try running dallas1wirereader with the software that comes with the station running at the same time (start that first)
Sorry…
No data flowing to 1-wirereader or new cronlazersnow as data is being logged by the LR4sample programs
the best thing is I need the hardware here
