Why not read from the log file. Set lrtimelog to read once an hour. Have wdisplay read the log file and subtract the last reading from the first reading to get the snow depth. You should be able to extract cm’s per hour etc from that as well. The file is in the following format.
2017-12-03 15:42:43.161, 107.6 cm
Probably not that simple but it should do away with having to use the 1-wire.
yes, I know about the forum certificate error
I am not the forum admin, so I can not help with that, sorry
re vid/pid hex
simply run windows device manager, then see the usb/hid devices, find your device (the lazer sensor) and it should show the vid/hid values there (properties)
I am including two devices as supposedly the Fluke 414D may be recognized as a keyboard in the Dallas1wire…I am not certain I am giving you the correct devices.
Found under HID device:
Device HID\VID_0417&PID_DD03&MI_00\9&14cb3d3&0&0000 was configured.
Driver Name: input.inf
Class Guid: {745A17A0-74D3-11D0-B6FE-00A0C90F57DA}
you have sent the correct info
does it say connected?
it might be that I need to send a command to get it to log
it might be that you need to run the software that comes with it at the same time
(try doing that with the dallas1wirereader program)
