1-wire reader & laser sensor
I’m trying to help a fella get his laser snow sensor up and running. The laser sensor is working correctly with all of the Porcupine Electronics software and the Dallas 1-wire reader is seeing the sensor, but is not taking any readings. In the 1-wire sensor there is this error “Default port does not have a driver”. I haven’t seen this problem before.
Any help would be greatly appreciated.
Thanks in advance.
Cheers
MikeyM
maybe needs the dallas 1 wire driver installed (and then once that is installed, select the default port for that in the driver setup)
or try selecting /setting up the port in the 1 wire setup in the dallas 1 wire driver section?
This was done without solving the problem.
Thanks for any additional suggestions.
W10 may be the issue.
screen shot?
I have sent 6 screen shots to [email protected] & MikeyM
Attached are 2 Dallas1wirereader.exe v5.7 screenshots
Thanks for any suggestions/help.
Maybe a typo in your post but it’s [email protected] with a hyphen.
Hi.
I have been using the fluke 414 and wd dallas for 3 years in wintertime.
But since last year the dallas 1-wire has not been stabil over long time or windows 10 regonize the fluke as not fluke but a keyboard, plug usb in out somtimes fix this.
Also tryed fluke readings one time an houre, but same issue dallas stoped working for reason unknown.
So i stoped using this feature in wd.
But hopefully somone can sort things out.
See photo, you also need to have this ticked “on”.
I have attached two screenshots of my Dallas1wirereader.exe app. v 5.7
It is running under Windows 10
Not sure how to troubleshoot the Keyboard issue you identified and whether I even have that problem.
All snow parameters are checked in WD
I can receive a daily one-time snow measurement by manually either directly or by remoting-in to my HP Laptop and running a manual measurement using porcupinelabs LR4 apps. Automatic flow of data just is not occurring at all using Dallas1wireader.exe & WD.
Appreciate you trying to help.
I downloaded my 64-bit 1wirereader driver from here:
https://www.maximintegrated.com/en/products/ibutton/software/tmex/download_drivers.cfm
@schwab
try
find the installed 1 wire driver dll files
like
IB97E32.dll
and copy to where you have WD installed
but the issue might be that you have installed 64 bit 1 wire drivers when only 32 bit driver needed
see if you can install the 32 bit dallas 1 wire drivers instead
the problem is I lost the code for the WD 1 wire program in a hard drive crash
I found the file you suggested and attached a screen shot of its location on my PC
Also…this is a site that may help? It is where I downloaded the 64-bit driver
Thanks…
UPDATE:
I tried to download the 32-bit one-wire driver from this site
but this failed because an applet popped-up and recognizes my PC running 64-bit Windows 10 and locks me out of downloading a 32-bit version.
Ideas?
try then deleting the 1 wire IB *.dll files from where WD is installed
Which of the files in the attached screen shot of my search shall I delete?
not those ones
the IB *.dll files from where WD is installed
(see my post)
not in the wow64 directory
but in the c:\wdisplay directory
i.e the IB97E32.dll and other IB (other name after that) dll files
OR
you can try deleting those IB dll files in the windows system folder and keep the ones in the WD folder
in your email it seems that the error you were getting about the port/driver in the WD 1 wire reader program is now gone, yes?
that is a step in the right direction
i think you now need to have set in WD, under control panel, com port setup, dallas 1 wire, set there. I want to use a 1 wire device.
in one of your screen shots of the WD 1 wire reader, it shows that WD is picking up the HID OK
This link to a technical article may be helpful to developers of the current dallas1wirereader.exe program and others with possible driver issues.
https://www.maximintegrated.com/en/app-notes/index.mvp/id/1740
does that mean you got it to work?
No. It is not working.
Not working how exactly
Any error message now?
The more info you can provide the better
Saying it does not work does not help
