i’ve been doing some more research on this off and on as time/work allows.
i was wondering - could i somehow use some 1-wire devices for this type of monitoring?
the location i want to monitor most is located on my property about 50 feet from the house (which is where my WD PC lives). both buildings have network (wifi, ethernet, even PoE), and power.
could i use a 1-wire temp/humidity sensor connected to a master which is tied into my network - would WD then be able to see it? in doing some searching on the forum i’ve found references to this kind of capability, but hadn’t yet found anything which directly states this would work (granted, i haven’t made it all the way through some of my search results).
