I noticed that cannot retreive the data logger’s informations manually.
WD say:
“trying to open the USB port
opening now
USB port failed to open”
It does not matter what time period is set.
I’m using the latest version of “WD”. The station is the irox / TE923 model
when you say manually, how do you mean exactly?
open /control panel/Data Logger, set the time interval (Manual adjust Start from Time/date), and press “Force load”
I had not tested , and so I need to do that
does the history data work on restart?
No, it doesn’t.
OK, I making progress with this
try a new update
(the data history screen should show up auto after 10 seconds)
Yes, now history data works on restart, and it is showing up auto after 10 seconds.
But after that “WD” can not connect to the console. The main screen has no current readings.
I did a clean installation, but it didn’t work. I restarted WD, but again I did not have success.
the problem will be with the fact that WD gets the history data but then has left the usb port open so that the separate usb reader program can not close it
I will see if I can get WD to close the port correctly
does the history data get read in OK though?
It does not seem to be read correctly. I checked the file 112017lg.txt and there are no new entries.
After a clean installation of “WD” and start of the program, the file 112017lg.txt is not created. No meaning allowed or forbidden is “Extract history data at program start up” in history settings.
a little part of data history screen
Looking for data from 22:32:00 11/25/17
History count position 0
opened ok
***write 152 0 0 0
write result 5
data received -1
data received -1
***write 152 0 0 0
write result 5
data received 34
baro= 0.0
hardware version =17 14 10 26
***write 252 0 0 0
write result 5
data received 34
baro= 170.6
Memory size is 8K , data interval is 30 minutes
next address 00 6
and etc
try another update
it should be better now
I’ll try.
The new update works. I checked 112017lg.txt, new readings are there. Also the main screen WD graphics are had updated. Cool.
