Author Topic: Davis console firmware 3.15 with VirtualVP and VSPE.  (Read 4550 times)
Offline ajcm73
  • Maspalomas, Canary Islands, Spain.
  • Firefox 56.0
    • MeteoMaspalomas
« on: November 04, 2017, 04:48:59 PM »
Hello:
I have firmware 1.90 in my davis console with virtualVP because I use 3 meteo software ( weatherdisplay, VWS and cumulusMX) but I upgrade the firmware 3.15 the software VWS donīt work and today I tested firmware 3.15 with VSPE but now Weatherdisplay donīt work. Somebody have firmware 3.15 with virtualvp, VSPE or other software that it works fine?
I have a weatherlink serial and I use Usb to serial adapter by Davis.
« Last Edit: November 04, 2017, 04:57:33 PM by ajcm73 »
Davis Vantage pro 2 plus with weatherlink serial using Virtual VP with Weatherdisplay, CumulusMX and VWS in Windows 10 Home 64 bits.
  • Davis VP2
  • Chrome 61.0.3163.100
    • Weather Display
Re: Davis console firmware 3.15 with VirtualVP and VSPE.
« Reply #1 on: November 04, 2017, 05:15:10 PM »
the problem is with the LOOP2 I think you will find
WD should work , if VWS is not running
Offline ajcm73
  • Firefox 56.0
    • MeteoMaspalomas
« Reply #2 on: November 04, 2017, 05:39:46 PM »
Then with firmware 3.15 I can not use the programs at the same time?
Another thing, I would like to connect the weatherdisplay directly to the davis console and not use virtualvp or anything. I use the weatherdisplay for my website but from the VWS I only need 2 data files and cumulusmx is only to save data i can delette this, so I would like to know if there is any way to connect the vws and the cumulusmx to the weatherdisplay program.
« Last Edit: November 04, 2017, 05:42:01 PM by ajcm73 »
  • Davis VP2
    • Weather Display
« Reply #3 on: November 04, 2017, 05:52:40 PM »
cumulus should still work
its VWS that is the problem
it detects the updated firmware and then requests the loop2 data, which stuff things up in virtualvp
Offline ajcm73
  • Firefox 56.0
    • MeteoMaspalomas
« Reply #4 on: November 04, 2017, 06:07:44 PM »
And I knew the problem with LOOP2 when firmware 3.12 came out two years ago, but now I was waiting for a solution to update the firmware.
I'll explain you well, my boot sequence order in startwatch is:
1st Cumulus MX
2nd VWS
3rd Weatherdisplay.
With firmware 3.15 and virtualvp cumulusmx and weatherdisplay work fine but VWS does not work.
But with firmware 3.15 and VSPE cumulusmx and VWS work fine but in this case weatherdisplay does not work.
I tried virtualvp then I tried VSPE and then I tried to use virtualvp and created virtual com ports with vspe and VWS did not work.
« Last Edit: November 04, 2017, 06:16:11 PM by ajcm73 »
  • Davis VP2
    • Weather Display
« Reply #5 on: November 04, 2017, 06:23:50 PM »
what was your reason to update the firmware?
Offline ajcm73
  • Firefox 56.0
    • MeteoMaspalomas
« Reply #6 on: November 04, 2017, 06:51:16 PM »
On internet the people coment that I must upgrade but I donīt have problems with firmware 1.90.
I like upgrade all things, all days I see your web page to find upgrades of weatherdisplay.
Thanks Brian.
« Last Edit: November 04, 2017, 06:53:07 PM by ajcm73 »
  • Davis VP2
    • Weather Display
« Reply #7 on: November 04, 2017, 07:27:13 PM »
yes, but, there is no real need to upgrade the davis console firmware, especially when its known to break virtual vp (this has been discussed on this and other forums before)
Offline ajcm73
  • Firefox 56.0
    • MeteoMaspalomas
« Reply #8 on: November 04, 2017, 07:32:29 PM »
Ok, thanks, I will come back with firmware 1.90.
