Author Topic: Updated WD then no updates from Vue  (Read 544 times)
Offline mickopla
  • Win 7/Srvr 2008R2
  • Chrome 61.0.3163.100
    • Waterford City Weather, Ireland
« on: November 03, 2017, 09:59:20 AM »
I'm using version R 306 and want to upgrade to the latest version. I tried the update procedure a number of months ago but initially data is received from the station but then it stops. i tried again last night with version s 59 and the same thing happened. I am now back at version r 306 and everything is working fine.
I need the latest version in order to use the api to update meteotemplate.
Where should i start with the troubleshooting? I have a Davis Vantage Vue weather station and WD is on Win 7
Edit: Data can only be extracted manually from the logger and also on restart station type disappears so this has to be entered again.
Regards
« Last Edit: November 03, 2017, 11:13:22 AM by mickopla »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Updated WD then no updates from Vue
« Reply #1 on: November 03, 2017, 06:15:05 PM »
any error under view, program event log?
Offline mickopla
  • Win 7/Srvr 2008R2
« Reply #2 on: November 03, 2017, 11:31:16 PM »
Tried again for a fourth time and magically its now updating. the joys of computing  :D
Offline mickopla
  • Win 7/Srvr 2008R2
« Reply #3 on: November 13, 2017, 02:56:42 PM »
I had to do a restart of WD today and my original problem has returned. No detection of my Vantage Vue when i use version S59. Could i copy the file that stores station data from version 306 and use that in s59?? Somehow the latest version is not detecting the vue and collecting data.
Nothing in the program event log either to shine a light on whats the issue.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 62.0.3202.89
    • Weather Display
« Reply #4 on: November 13, 2017, 06:10:47 PM »
do you happen to have a direct to serial (e.g desktop/power pc)
if so then make sure to be using the latest build 59 update
Offline mickopla
  • Win 7/Srvr 2008R2
« Reply #5 on: November 14, 2017, 10:50:21 AM »
I updated to the latest version of build 59 and still the same issues. I'm back at version 306 again which is working fine. Obviously no Meteotemplate api option in that build so had to use the Meteohub plugin to update. Previous to 306 i did regular updates with no issues but then got a bit lazy i guess and had the if it isn't broke don't fix it mentality.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #6 on: November 14, 2017, 07:02:59 PM »
do you have a serial connection by any chance (i.e a desktop pc with direct serial)
the more information you can provide the better
Offline mickopla
  • Win 7/Srvr 2008R2
« Reply #7 on: November 14, 2017, 11:10:40 PM »
I have a USB connection from the Vue to PC
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: November 15, 2017, 01:06:10 AM »
that should be OK
try it again
then in WD under setup, advanced/misc, tick, log the raw data
and then let me know what shows under view, debug info
Offline mickopla
  • Win 7/Srvr 2008R2
  • Chrome 62.0.3202.94
« Reply #9 on: November 15, 2017, 08:57:59 PM »
that should be OK
try it again
Hi Brian
Just this info in the debug log
Doing checking of time zone calculation
Daylight saving not in use
Loaded all time records
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #10 on: November 15, 2017, 09:16:05 PM »
it should have information there about connecting to the com port. etc
what shows under view, program event log?
Offline mickopla
  • Win 7/Srvr 2008R2
« Reply #11 on: November 15, 2017, 09:42:13 PM »
this Brian
error loading all time records Device "COM7" Open Error !!!
Access is denied
Edit: Fixed the problem, The inspeed vortex was on com7 so it was loading that first instead on the davis vue. I switched that off and everything loaded fine. Then added the inspeed :D
« Last Edit: November 15, 2017, 09:48:42 PM by mickopla »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #12 on: November 16, 2017, 01:31:35 AM »
so you mean the inspeed was set to the wrong port?
I need to have better error trapping around that (ie so that other things carry on)
Offline mickopla
  • Win 7/Srvr 2008R2
« Reply #13 on: November 16, 2017, 10:41:33 AM »
No Brian the inspeed was set to the right port but on start the software was only connecting to the inspeed so no data was coming from the Vue. So i switched off the inspeed and restarted and all the Vue data came through. Then i just added the inspeed and all working fine.
It seems because the inspeed was connected to port 7 the software was thinking there is nothing else connected so wasn't detecting the Vue.
This wasn't an issue with version 306.
