Author Topic: Davis Vue Humidity Readings  (Read 746 times)
Offline mickopla
  • Win 7/Srvr 2008R2
  • Chrome 61.0.3163.100
    • Waterford City Weather, Ireland
« on: October 23, 2017, 11:35:44 AM »
My Vue is over 7 years old and was working ok up to recently. My issue is the Humidity readings will not read over 90%. In cases where i know it should read near 100% it still stays at 90. Any ideas on anything i can check or is it a case of a new ISS?
cheers
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Davis Vue Humidity Readings
« Reply #1 on: October 23, 2017, 06:02:27 PM »
you could try replacing just the temp/hum sensor
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
  • Chrome 62.0.3202.62
« Reply #2 on: October 23, 2017, 07:03:21 PM »
I don't think you can do that on the Vue...
Offline mickopla
  • Win 7/Srvr 2008R2
« Reply #3 on: October 23, 2017, 08:41:12 PM »
Yes i do believe from reading other threads that Davis are not providing replacement temp/hum sensors anymore.
Offline dghillcroft
  • iOS 11.2.1
  • Safari 11.0
« Reply #4 on: December 27, 2017, 10:37:59 AM »
I have had 4 Vue humidity sensors fail. The first time was after 5 years of use the readings started to go haywire, eventually reading 1%. I replaced the complete sensor head but had another failure within 6 months. I made a claim under the warranty and the agent sent me a new sensor, which I fitted. This worked for about 6 months before failing again. This time the agent had the complete head back and replaced the sensor. They complained that the head was infested with small fruit flies and this might have been the cause of the failure. A further 6 months on the humid readings started going haywire plus the temperature started reading -67 (it was the height of summer!). I stripped the head down and found a large number of fruit flies so at this point I decided to use my old unit and forget humidity readings. After looking around at what other systems are available I have purchased a WMR300 and will bin the Vue. I will site the new system further away from the house and hope the sensors donít get too much attention from flies.
