Today cannot run a forecast because the error is
: “fdata.txt too short for use”
and wxsin does not a forecast
Whats happend?
Stefan
Whats happend?
Stefan
I try this from SteveFitz1:
“Are getting you a complete “clean” WxSim-Lite run? If you’re not sure, can you go into WxSim-Lite, click Schedule on the menu tab, click the Run Immediately checkboxes for both Forecast and Analysis, then click Enable Scheduler. Let this run to completion and it will either finish cleanly or stop on an error.”
Mabye this helps…
Yes this are helps WXSIM does a forecast, watching now for the next run
Did you get this fixed?
Tom
Hi Tom
Yes, see last post above, that helping me.
