Just unzip the WD-trends-inc-1.07.zip – it has one file ‘WD-trends-inc.php’ in it. Just upload it to your website in the same directory as wxtrends.php, Settings.php (etc) of the template. (note that it has to be named ‘WD-trends-inc.php’ and not ‘wd-trends-inc.php’ – *nix servers care about upper/lower case in filenames (unlike Microsoft).
The default settings inside the file are automatically overridden by your settings in Settings.php so no changes are needed to that file.
Your version of testtags.txt template does support the Dew Point trends.
Thanks, Ken! I think the addition of Dew Point is worthwhile.
A caveat, though. Users should be aware that only the ‘Current’ values are updated via AJAX, not the entire page. On my site I’ve included a message to this effect along with a page refresh link. Here is the code, in context:
<span class="ajax" id="ajaxtime"><?php echo adjustWDtime($time); ?></span> </h2>
<p> (<b>NOTE:</b> Only the 'Current' values are auto-updated while the rest of the page is static. For a full page refresh click <a href="wxtrends.php">here</a>.)</p>
@Ken, one tiny little aesthetic issue I noticed. The initially loaded current baro has 3 dp like the rest of the table, but the Ajax updated value (converted from hPa in clientraw I assume) only has 2 dp.
And, the new current Dew Point display will only update with the corresponding change in ajaxWDwx.js.
I’d hoped that the green flashes would alert folks that those variables are/have-been updated. Very true that the bulk of the display on the page is done from testtags.php at page-load time, so it is only updated when the page reloads (and that after an update to testtags.php has been done).
Yes… the raw $baroNminuteago numbers are just echo/print of the raw values with no extra formatting. The AJAX updates do use reformatting (and conversion) from clientraw.txt. I don’t have a current mechanism in the Settings areas to set the default decimal places for the variables (but could likely suppose them from the units (mb/hPa=1, inHg=2 ). So far, only the baro readings seem out of whack in the raw data with the extra decimal place of precision. Although, going the other way (setting ajaxWDwx.js to use 3 decimals of precision) would make the table ‘harmonious’ and the display show the subtle changes in pressure better. Easy enough change in ajaxWDwx.js
var uomTemp = '°F';
var uomWind = ' mph';
var uomBaro = ' inHg';
var uomRain = ' in';
var uomHeight = ' ft';
var dpBaro = 2;
var dpRain = 2;
to
var uomTemp = '°F';
var dpBaro = 3;
var dpRain = 2;
I guess I should have used ‘viewer’ instead of ‘user’ as the target of my modification. Because the rows of data are timed, as time passes the term ‘x minutes ago’ loses more and more relevance. I have added the time that the page was initially loaded in order to show how stale the ‘x minutes ago’ have become:
For a full page refresh click <a href="wxtrends.php">here</a>. This page was last fully loaded at <?php echo date("g:i A",time())?>.)</p>
<h2><?php echo langtrans('Trends as of'); ?> <span class="ajax" id="ajaxdate"><?php echo adjustWDdate($date); ?></span>
<span class="ajax" id="ajaxindicator"><?php langtrans('at'); ?></span>
<p>(<small>
<?php langtrans('Note: Only the \'Current\' values may be updated in near-realtime, while the other values are current when the page is loaded.'); ?>
<?php langtrans('The other data was from ');
echo '<strong>'.adjustWDdate($date). " " . adjustWDtime($time)."</strong>. ";
langtrans('Reload this page for updated data');
?>.)</small></p>
near the top. That allows for translation using
langlookup|Note: Only the 'Current' values may be updated in near-realtime, while the other values are current when the page is loaded.|Note: Only the 'Current' values may be updated in near-realtime, while the other values are current when the page is loaded.|
langlookup|The other data was from |The other data was from |
langlookup|Reload this page for updated data|Reload this page for updated data|
langlookup|DEW POINT|DEW POINT|
in the language-LL.txt translation file to convert to the selected language. Also, I’d used the Settings.php specs for date/time presentation.
Did a bit more adjustments for international support, so here’s the final one I’ll distribute shortly. The ajaxWDwx.js script defaults to English units, so change the settings inside for Metric if needed. It handles the dew point with no units update also.
The Baro column will display 3 decimals (for English) or 1 decimal for Metric so it matches what WD produces for the variables in testtags.php for the respective displays.
Many thanks again, Ken! A slightly modified version of your better thought-out changes is up and running on my site.
Just a heads-up for those who are using Scott Thompson’s version 6.x alternate dashboard, you can download a compatible minified ‘ajaxWDwx3.js’ as a ‘.txt’ file here and the source file, which is 7/3 larger, as a ‘.txt’ file here.
