Author Topic: Ambient Weather WS-1002 WIFI  (Read 577 times)
Offline meckley0710
    • scott.meckley
  • Win NT 10.0
  • Chrome 52.0.2743.116
« on: September 03, 2017, 12:15:32 AM »
Hi I just recently DL'd WD for my WS-1002 WiFI and I can't Seem to figure out why it won't work consistently. If I reboot my PC and start it fresh, it will work for a few hours and then the data slowly dissipates. It works for a few hours then stops for varying periods and at some point just stops working all together. Hopefully I'm doing something wrong.
Thank You
Scott
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 60.0.3112.90
    • Weather Display
Re: Ambient Weather WS-1002 WIFI
« Reply #1 on: September 03, 2017, 01:52:19 AM »
you should untick the first setting
as you have not changed the URL (from being yourwebsite.com)
does your station have a console?
Offline meckley0710
    • scott.meckley
  • Win NT 10.0
« Reply #2 on: September 03, 2017, 02:10:07 AM »
Yes it does.. Now it will not work at all.. I really think my biggest problem is I don't understand the settings or how to use them.. If I tick all the boxes it works (for a few hours)and change anything it stops..
Thank You
Scott
Offline meckley0710
    • scott.meckley
  • Win NT 10.0
« Reply #3 on: September 03, 2017, 02:17:16 AM »
Check that.. It's working now with these settings using wifi direct on the 192.168.1.255. What is that IP??
Hopefully it continues :)
thank You
Scott
Offline meckley0710
    • scott.meckley
  • Win NT 10.0
« Reply #4 on: September 03, 2017, 02:30:10 AM »
It stopped again.. I looked in the router and found the internal IP the console runs on, changed the IP to that.. We'll see
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #5 on: September 03, 2017, 05:37:55 AM »
ah, you will need to set a fixed IP address in the router for the station
have you tried ticking the usb option?
Offline meckley0710
    • scott.meckley
  • Android 8.0.0
  • Chrome 60.0.3112.107
« Reply #6 on: September 03, 2017, 01:17:46 PM »
The console is entirely wireless. It's assigned to 192.168.1.12 that's how I set it up. It worked for 5 hours and stopped receiving data. When I got up this morning I restarted WD and it started working again. I'm at a loss what to try next.. Thank you for your replies
Scott
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #7 on: September 03, 2017, 07:59:43 PM »
yes
but its still going through your router
you can set a fixed IP address there
have you tried ticking to use the usb option? (that will work if you are able to see the actual  console folder under my computer)
