Author Topic: Testtags upload issues  (Read 1118 times)
Offline Martyn
  • Davis VP2+ FARS/solar/UV
  • Bristol, UK
  • Win 7/Srvr 2008R2
  • Firefox 55.0
    • Horfield/Filton, Bristol, UK weather station
Re: Testtags upload issues
« Reply #30 on: September 05, 2017, 02:07:36 PM »
control panel -> FTP & connections METAR/NOAA -> web cam upload.
Martyn,
Bristol, UK
Twitter: https://twitter.com/HorfieldWeather
FB: https://www.facebook.com/bristolweather
CWOP: CW2888
WU: IBRISTOL3
Offline K3JAE
  • CoCoRaHS: TN-CR-7; WxUngrd: KTNBRUCE2; CWOP: AT066
  • Carroll County, TN, USA
  • Win 7/Srvr 2008R2
  • Firefox 55.0
    • K3JAE's Weather Station
« Reply #31 on: September 05, 2017, 02:13:36 PM »
This is my current setting for FTP.
73's de K3JAE
John
K3JAE Weather Station
Offline Martyn
  • Bristol, UK
  • Win 7/Srvr 2008R2
  • Firefox 55.0
« Reply #32 on: September 05, 2017, 02:18:42 PM »
I can see both SkyCam.jpg and SkyCam.gif on your server - the .gif seems to be up to date but I think the .jpg is from yesterday (can't quite make out the date and atime on the image as it is small).
In your CamImages directory is the modified date/time of the .jpg up to date? The same stale image might be getting uploaded all the time?
Can you see the .gif and .jpg being reported as uploaded ok in ftplogfull.txt (in wdisplay directory)?
Martyn,
Bristol, UK
CWOP: CW2888
WU: IBRISTOL3
Offline Martyn
  • Bristol, UK
  • Win 7/Srvr 2008R2
  • Firefox 55.0
« Reply #33 on: September 05, 2017, 02:25:26 PM »
I think the settings in the webcam capture need to be checked, in your screenshots I can see "saving 2nd file ......"  and mine just says "saving file ....". Is that a .gif or .jpg being saved? If it is not a .jpg then that is why a current jpg image is not being uploaded.
There is a tab called "#2 webcam" - have you got a file being created there?
« Last Edit: September 05, 2017, 02:28:09 PM by Martyn »
Martyn,
Bristol, UK
CWOP: CW2888
WU: IBRISTOL3
Offline K3JAE
  • Win 7/Srvr 2008R2
  • Firefox 55.0
« Reply #34 on: September 05, 2017, 03:06:19 PM »
There is NO mention of SkyCam.jpg being uploaded in the ftplogfull.txt file - only the animatedweabcam and SkyCam.gif.
The SkyCam.jpg is NOT up to date. Not exactly sure which file would be the "modified" file name.
73's de K3JAE
John
Offline K3JAE
  • Win 7/Srvr 2008R2
  • Firefox 55.0
« Reply #35 on: September 05, 2017, 03:14:45 PM »
I had, at one time ticked the second file save but no longer. There is nothing set up under 2nd file tab.
Below are screen shots of the same thing - just moved a bit to the right (in the window by the cam capture window) to show it is saving the SkyCam.jpg. BUT is is not uploading it.
EDIT: UPDATE: I just found the following in the ftplogfull.txt file which I feel certain this is where the issue lies... but not sure how/where to resolve....
Uploading C:\wdisplay\CamImages\SkyCam.jpg -> animatedwebcam.gif
So if I am interpreting this properly it is renaming the SkyCam.jpg to animatedwebcam.gif? Looking at this file indeed is the updated webcam image... I must have something amiss in the animated portion of the setup? How does a jpg file become an animated gif?  It cannot to my knowledge.
I went to the Animated Webcam Image Setup and attempted to change from SkyCam.jpg to SkyCam. gif and it refuses to change. However Brian's video DOES show it is using a jpg to create the animate webcam so leaving it as jpg.
« Last Edit: September 05, 2017, 03:44:29 PM by K3JAE »
73's de K3JAE
John
Offline Martyn
  • Bristol, UK
  • Win 7/Srvr 2008R2
  • Firefox 55.0
« Reply #36 on: September 05, 2017, 03:48:42 PM »
Yes indeed - here is your up to date webcam image at http://www.k3jae.com/animatedwebcam.gif
I expect Brian will have to check your settings. I don't have anything set up in control panel - > webcam as I am not creating video or animated gifs. Maybe there is a conflict.
« Last Edit: September 05, 2017, 03:52:43 PM by Martyn »
Martyn,
Bristol, UK
CWOP: CW2888
WU: IBRISTOL3
Offline K3JAE
  • Win 7/Srvr 2008R2
  • Firefox 55.0
« Reply #37 on: September 05, 2017, 03:56:58 PM »
I'm wondering if I just disable making an animated gif if that would resolve it?  I really do not need one so... I will do that as a temp potential fix and see what happens.
UPDATE: Disabling the animated gif making did stop the renaming of SkyCam.jpg to animatedwebcam.gif ---- HOWEVER now it is renaming SkyCam.jpg to SkyCam.gif????
So, again as a temporary resolve, I have re-coded my image file to display on the ajax dashboard from SkyCam.jpg to SkyCam.gif and it appears to be showing properly. We shall see in about an hour if it continues to update properly. This does not resolve the underlying issue fully but simply makes the site appear that is is working properly.
Hopefully Brian will follow through all our bantering back and forth and see if there is something else I have amiss.
To review all previous messages into one message:
  • I disabled the creation of the animated webcam temporarily because having it active only served to cause SkyCam.jpg to be renamed to animated webcam.gif.
  • Having disabled the Animated gif creation now forces SkyCam.jpg to be renamed SkyCam.gif.
  • I have re-coded my ajax-dashboard to display SkyCam.gif as opposed to my original coding (and preference) of SkyCam.jpg and images shows properly. SkyCam.gif appears to be updating and uploading as designed.
  • Why is SkyCam.jpg still being renamed to SkyCam.gif?
  • Why is SkyCam.jpg not being uploaded as is preventing me from being able to use SkyCam.jpg as my image on the AJAX dashboard?
« Last Edit: September 05, 2017, 04:21:41 PM by K3JAE »
73's de K3JAE
John
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 60.0.3112.90
    • Weather Display
« Reply #38 on: September 05, 2017, 05:54:57 PM »
Quote
that is the problem
what I was looking for though was your web cam upload settings in WD
Offline K3JAE
  • Mac OS X 10.12.6
  • Safari 10.1.2
« Reply #39 on: September 05, 2017, 09:02:12 PM »
I did send that I think - a few msgs back... Unless I am misunderstanding what screen you need...  8O
73's de K3JAE
John
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #40 on: September 05, 2017, 10:52:57 PM »
OK, I see that now
one problem I see there is you have a gif file to be uploaded
but the web cam software is not set to produce a gif file (only a jpg file)
delete that
Offline K3JAE
  • Win 7/Srvr 2008R2
  • Firefox 55.0
« Reply #41 on: September 05, 2017, 11:46:41 PM »
OK, the gif file has been removed from that upload.
Now seeing the following in the ftplogfull.txt:
Uploading C:\wdisplay\CamImages\SkyCam.jpg -> formateddata.txt
Deleting the gif file upload has stopped my uploading of the SkyCam.gif file now as well. last upload was 18:37 - it is now 19:00.
« Last Edit: September 05, 2017, 11:58:05 PM by K3JAE »
73's de K3JAE
John
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #42 on: September 06, 2017, 08:03:20 AM »
i suspect that somewhere you have a double up of filenames
the best thing is to .zip and email me your settings files ( PM me for an alternative email address)
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #43 on: September 08, 2017, 11:28:17 PM »
we got this sorted
