Author Topic: WD appears to have exploded.  (Read 1412 times)
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 60.0.3112.90
    • Weather Display
Re: WD appears to have exploded.
« Reply #30 on: August 31, 2017, 10:20:57 PM »
one thing I do see in your settings is that you are using a web cam image
the problem could be with a corrupted image file
Offline NorCal Dan
  • Dan - KJ6RGX
  • Davis Vue/Win10
  • Ocean Park, WA.
  • Win NT 10.0
  • Chrome 60.0.3112.113
    • Traveling RV Weather
« Reply #31 on: September 01, 2017, 03:18:38 AM »
When you note make a wd2.txt file... I assume this is a blank file in the wdisplay (or new folder) root?
Just a blank file in the WD directory...assuming that WD still has the capability.
The way it worked is when WD detects the file it starts up a second version, using absolutely nothing from your original install...to include registry settings.  The fact that yours failed to run means either this functionality has been removed from WD, or, WD did not detect the file.
I just searched old posts and now I see references to 2wd.txt as the file name...the part i quoted earlier was directly from Brian's post so I figured it would be correct.
« Last Edit: September 01, 2017, 03:22:20 AM by NorCal Dan »
Offline Ruben Perez
« Reply #32 on: September 01, 2017, 06:58:18 AM »
I think it could be, maybe some corruption on PC files (not related to WD), or maybe some HW failure on weather station hardware. Can you test the weather station with other software? Can you pass some corruption test to the PC? Which operating system runs?
Ruben
Enviado desde mi Nexus 7 mediante Tapatalk
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #33 on: September 01, 2017, 08:57:07 AM »
its most likely was due to a corrupted web cam image file, which cause a run away in memory (race condition)
Offline K3JAE
  • CoCoRaHS: TN-CR-7; WxUngrd: KTNBRUCE2; CWOP: AT066
  • Carroll County, TN, USA
  • Win 7/Srvr 2008R2
  • Firefox 55.0
    • K3JAE's Weather Station
« Reply #34 on: September 01, 2017, 04:23:12 PM »
Any way to remove that possible corrupted webcam file and restore?
73's de K3JAE
John
K3JAE Weather Station
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #35 on: September 01, 2017, 06:19:18 PM »
simply delete it
Offline K3JAE
  • Win 7/Srvr 2008R2
  • Firefox 55.0
« Reply #36 on: September 01, 2017, 06:23:14 PM »
Gee... why didn't I think of that...  :roll:  :oops:
OK. Easy enough!!
73's de K3JAE
John
