Author Topic: %mintemp% Sometimes Reports 0.0 Degrees Unexpectedly  (Read 716 times)
Offline FPGAgeek
  • Davis VP2
  • Dorset, UK
  • Win 7/Srvr 2008R2
  • Firefox 55.0
    • Basstudio Weather
« on: August 23, 2017, 05:02:15 PM »
I have only seen this a handful of times where the daily low temperature is reported at 0.0-degrees Celsius (see attached) even though the graph and data log don't have equivalent data recorded. I think this spurious low temperatures also get logged in the monthly all-time low temperature records too as I currently have July (%recordlowtempjul%), August (%recordlowtempaug%) and September (%recordlowtempsep%) all of which reporting 0.0-degrees in 2016.
This is a similar to this discussion here: https://www.weather-watch.com/smf/index.php/topic,65482.0.html
I am not sure why this happens, is there anything I can do to test this further?
Any thoughts, thanks guys?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 60.0.3112.90
    • Weather Display
Re: %mintemp% Sometimes Reports 0.0 Degrees Unexpectedly
« Reply #1 on: August 23, 2017, 08:40:48 PM »
what weather station type?
Offline FPGAgeek
  • Davis VP2
  • Dorset, UK
  • Android 5.0.2
  • Chrome 59.0.3071.125
    • Basstudio Weather
« Reply #2 on: August 23, 2017, 09:33:51 PM »
Davis VP2 connected via native RS232.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: August 23, 2017, 09:41:02 PM »
it could be a periodic fault in the temperature sensor?
you could try setting a minimum temperature value limit in WD as a test (control panel, offsets, limits)
Offline FPGAgeek
  • Davis VP2
  • Dorset, UK
  • Android 5.0.2
    • Basstudio Weather
« Reply #4 on: August 24, 2017, 06:32:58 AM »
Yes it could be - what I will do then is tap off the received VP2 RS232 data to another computer such that I have the raw data logged if and when it happens again for comparison.
How does WD manage the samples from the VP2 regarding temperature i.e. are the high/lows compared against each sample received and the current temperature logged (per minute) an average of the samples received?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #5 on: August 24, 2017, 08:13:03 PM »
all the data received over a minute is averaged for the data/log file
but each data point received is used for the max/min of the day
Offline FPGAgeek
  • Davis VP2
  • Dorset, UK
  • Win 7/Srvr 2008R2
  • Firefox 55.0
    • Basstudio Weather
« Reply #6 on: August 24, 2017, 08:36:29 PM »
That makes sense.
I will setup a RS232 logger connected to the VP2 data to see if I capture anything, I have only seen this 3x times (i think) before, this was last year so I am not sure if I will capture anything of interest but I will try.
Offline FPGAgeek
  • Davis VP2
  • Dorset, UK
  • Android 5.0.1
  • Chrome 60.0.3112.107
    • Basstudio Weather
« Reply #7 on: September 05, 2017, 07:21:34 PM »
I saw this issue again on Sunday at 00:26hrs. Unfortunately I hadn't setup my VP2 data capture  #-o I have definitely set it up now and its capturing all VP2 data transmitted from the console to the weather PC interface.
Offline FPGAgeek
  • Davis VP2
  • Dorset, UK
  • Win 7/Srvr 2008R2
  • Firefox 56.0
    • Basstudio Weather
« Reply #8 on: October 11, 2017, 05:58:40 PM »
So after quite a few days of logging Davis VP2 serial data using a standalone PC, I finally captured some data while a faulty 0.0-degrees (outside low temperature) was reported in WD.
Background
Note, this issue doesnít manifest itself often on my setup.
I logged all the data transmitted from the Davis VP2 console by picking off the data transmitted over the-wire i.e a second received copy of the data using a standalone PC.
The PC data logger date and time stamped the data received such that I could correlate the WD data with the captured VP2 data reception. I also checked that the two computer (WD and data logger) clocks were relatively synchronised for data correlation purposes - the logger was approx 20-seconds ahead.
The rogue temperature reading was recorded on 2017/10/08 04:12 local time by WD.
Update
Interestingly the Davis VP2 LOOP data around the time of occurrence (04:12 +/-2-mins) all report a temperature of 50.n-degrees with no rogue 0.0-degree readings. However one anomaly that can be seen in the data log at 04:13:13 is a pause in transmission of a LOOP response packet as shown below:
Code: [Select]
2017/10/08.04:13:11
4C 4F 4F 00 00 5E 09 59 75 9E 02 3F F5 01 02 03 | LOOP
2C 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FF 5E FF FF FF FF FF FF FF 00 00 00 00 00 00 00
FF FF 00 00 11 00 04 0A 00 00 28 00 BA 01 FF FF
FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 34 03 06 2C CE 02 25 07 0A
0D E5 D5
2017/10/08.04:13:13
0D E5 D5                                        | LOOP (CRC=good)
06                                              | ACK (COMMAND)
FF FF 00 00 11                                  | LOOP halt
2017/10/08.04:13:14
               00 04 0A 00 00 28 00 BA 01 FF FF | LOOP continue
2017/10/08.04:13:15
0D E5 D5
So it looks like the Davis VP2 concole paused transmission of a LOOP response packet for approx 1 to 2-seconds while it was servicing a higher priority interrupt possibly. Although I canít guarantee this because the PC logger is running under Microsoft Windows which is not an real-time operating system (RTOS) i.e. the pause may have been in the PC data logger. I will need to double check this for other occurrences in the logged data that I have.
If what I captured is a genuine pause of the VP2 console transmitting the LOOP response packet, could this be a possible cause for WD to log 0-degrees?
Offline FPGAgeek
  • Davis VP2
  • Dorset, UK
  • Win 7/Srvr 2008R2
  • Firefox 56.0
    • Basstudio Weather
« Reply #9 on: November 05, 2017, 09:31:39 AM »
And another one - this one also showed up on the WD graph :?
Currently running WD 10.37Sb59 (2017/11/05).
This one occurred Sunday at 04:23am (2017/11/05) and the previous one was Sunday 04:12am (2017/10/08), anyone know what could be happening at this day and approx time?
Offline FPGAgeek
  • Davis VP2
  • Dorset, UK
  • Win 7/Srvr 2008R2
  • Firefox 56.0
    • Basstudio Weather
« Reply #10 on: November 12, 2017, 09:26:55 AM »
And another (running WD 10.37Sb59 - 2017/11/05).
This one occurred Sunday at 04:37am (2017/11/12). I also had 5x other occurrences this week but I have been away so haven't been able to report back here.
It feels like the problem has got worse since the updates for this http://www.weather-watch.com/smf/index.php/topic,65750.0.html bug.
Offline FPGAgeek
  • Davis VP2
  • Dorset, UK
  • Win 7/Srvr 2008R2
  • Firefox 56.0
    • Basstudio Weather
« Reply #11 on: November 14, 2017, 06:41:35 PM »
I am getting 0-degree glitches at least once a day following the recent WD updates (see previous reply).
I caught another glitch while recording the VP2 traffic using a separate PC, again tapping off the RS232 wire transmitted by the VP2 console to WD. After a few painful hours of processing the data I found this:
Code: [Select]
2017/11/12.17:13:23
06                                              | ACK (COMMAND)
4C 4F 4F 3C 00 86 09 23 75 B4 02 32 B3 01 0F 07 | LOOP
42 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FF 4E FF FF FF FF FF FF FF 00 00 00 00 00 2B 00
11 B5 07 00 87 00 62 0B 23 00 20 00 2E 02 FF FF
00 00 00 00 00 00 00 33 03 06 4B CC 02 59 06 0A
0D 80 50
0D 80 50
FF 4E FF FF FF FF FF FF FF 00 00 00 00 00       | Loop halt
2017/11/12.17:13:24
                                          2B 00 | LOOP continue
0D 80 50
Look above where I have annotated the LOOP halt/continue. The VP2 console is stalling the transmission of a LOOP packet for approx 1..2-seconds compared with a normal transmission, note the date/time stamp is tagged by the capture software I am using. This effect is exactly the same when I captured the data from a previous glitch (see reply #8 in this thread). Another point to note is that the stalled LOOP packet has exactly the same content including CRC as the previous LOOP packet giving a clear indication that the VP2 console processor clearly paused the RS232 transmission, probably while processing a higher priority interrupt - I am guessing saving data in EEPROM due to the duration.
My VP2 console (#6312) is an older hardware revision (pre April 2006) with firmware v1.90 with a native RS232 data logger i.e. no USB.
Brian: any thoughts as this looks to be a WD issue handling the VP2 data port when LOOP packet transmission is paused mid-flight? I may contact Davis technical support and find out what the pause duration could be if that helps.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 62.0.3202.89
    • Weather Display
« Reply #12 on: November 15, 2017, 02:52:22 AM »
seems to be more of a hardware issue in the the first place (with your particular hardware version etc)
not sure how WD can handle your particular problem (with I do not have other reports of)
except for just using the temperature limits already in WD (i.e setting a lower temperature limit above zero so that WD will ignore this problem, sort of thing)
Offline FPGAgeek
  • Davis VP2
  • Dorset, UK
  • Win 7/Srvr 2008R2
  • Firefox 56.0
    • Basstudio Weather
« Reply #13 on: November 15, 2017, 05:27:27 PM »
Yeah possibly. We will have to see what Davis technical support report back, that is if I get a response to my questions. The Davis VP2 Serial Communications Reference Manual doesn't clearly clarify the packet transmission periods i.e. the idle time between data frames (byte transmission including start and stop bits).
Setting the temperature limit in WD is just not an option for my climate as I will end up masking the real world temperatures.
