Author Topic: USB ISOLATION iCoupler ground loops  (Read 1236 times)
Offline MichaelPT
  • Staffordshire Nr Leek
  • Android 7.0
  • Chrome 51.0.2704.106
    • Weather-Above
« on: August 22, 2017, 11:39:27 PM »
Usb isolation module have come down in price, and there are lot more available. It's a good way to  stop ground loops
and gives your pc / laptops USB protection
 something to think about on your computer system
 information on the one I am using on the 1 wire weather station
port USB isolator. supports USB 2.0 full speed data mode (12Mbps*)
and low speed mode (1.5Mbps*). You can install the USB-4620 module in any USB port
that supports the USB 2.0 standard.
USB-4620 is equipped with a LED indicator that show the working status. USB-4620 also
features the DIN-rail mounting capability and plastic hanging bracket that provide the
rigid connections in any working enviourment.
 As an option to use with external power supply
« Last Edit: August 22, 2017, 11:41:05 PM by MichaelPT »
