Author Topic: Difference in Zip update and Full install  (Read 723 times)
Offline oreitsma
  • Assen, Netherlands
  • Win NT 10.0
  • Chrome 60.0.3112.90
    • Weerstation Assen
« on: August 13, 2017, 08:35:15 AM »
There is a difference in the WD Zip update (is ver. 10.37S54) and Full install (is ver. 10.37S56)
Is it not possible to change with Zip update?
Brgds,
Oebel
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Difference in Zip update and Full install
« Reply #1 on: August 13, 2017, 08:47:29 AM »
there has not been enough people using the full install often enough I have found (and so they have been missing out on some of the files that have been updated)
Offline oreitsma
  • Win NT 10.0
    • Weerstation Assen
« Reply #2 on: August 13, 2017, 08:54:48 AM »
Oké. Clear.
Thanks!
Brgds,
Oebel
Offline CurtisZM
  • Zumbrota, MN
  • Win NT 10.0
  • Firefox 55.0
    • CurtisZMWeather
« Reply #3 on: August 13, 2017, 04:26:28 PM »
Brian,
 I did not know that either.
 Could I make a suggestion. Add in the main download page a bold message on how you should update WD. I see WD-FAQ has a link that was created by snowman.
  http://www.weather-watch.com/smf/index.php/topic,6265.0.html
 Maybe say in bold: Weather Display install file version# is the one that should be used for normal program updating
  Thanks Brian.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #4 on: August 13, 2017, 07:19:34 PM »
but it does not need to be used every time
now is a good chance for people to do a full update
Offline jgillett
  • John - W7JKG
  • Phoenix, AZ
  • Mac OS X 10.12
  • Firefox 55.0
    • TiggrWeather Phoenix
« Reply #5 on: August 14, 2017, 04:29:06 PM »
So how do we know exactly when is a good time to use the full update??
John
W7JKG
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #6 on: August 14, 2017, 08:48:52 PM »
now is a good time
Offline bhassell
  • KA5ZCI
  • Laplace, Louisiana
  • Win NT 10.0
  • Chrome 60.0.3112.101
« Reply #7 on: August 18, 2017, 04:28:29 PM »
Brian....Ok...Against better judgement, I did the Full install and can no longer run.
 I get the following error "weatherdisplay.exe-Entry Point Not Found  The procedure entry point _except_handler4_common could not be located in the dynamic link library msvcrt.dll"
Seems I had this in the past and you had me go BACK to a version 51 i believe and said to ONLY use the "WD Zip Update" file.
Can you get me back up and running again?
Running on Windows Server 2003
« Last Edit: August 18, 2017, 04:35:39 PM by bhassell »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: August 18, 2017, 06:29:40 PM »
you could try using the build 81 full download
http://www.weather-display.com/downloadfiles/wdisplay32build81.exe
and then if you use the normal full install but install to a different location and then try copying the .exe files to the normal location
Offline bhassell
  • KA5ZCI
« Reply #9 on: August 18, 2017, 07:31:54 PM »
Worked out fine....I think a CAVEAT needs to be added for those of us running on older platforms to use the "Install to different location and copy only the EXE files to normal location". I did not lose any old data or installed devices...but gave my old heart a STRESS TEST.  Thanks again Brian...I need to send more funds for your Beer Hand.  Lol
Sent from my iPad using Tapatalk
