Author Topic: long-standing frustration with WD  (Read 308 times)
Offline gorlash
  • Win 7/Srvr 2008R2
  • Firefox 52.0
« on: August 12, 2017, 06:02:17 PM »
I've been using WD for about a decade now.  It works fine, but there is *one* problem that I've always had with it...
Any time I want to change the size of the entire main window, I have trouble; there doesn't really seem to be a way to predictably do this...
There are 3 'resize' controls on Setup menu:
1. increase screen size
2. set screen size % increase from normal
3. reset screen size and then restart.
None of these really performs predictable actions, though.
<1> blows the window up *really* big, typically throwing the bottom of the window off the screen
<2> does *something*, I'm not sure what, but it does not seem to be related to the number that I enter in the Percent dialog; i.e., 120% does *not* necessarily make the window larger than the default 80% does.  I have *no* idea what "normal" refers to in this context; I would expect 80% to make it smaller than it already is, but that does not really seem to happen.
<3> is the most consistent of them; it resets the window to roughly 700x500 or so
ITM, what would be ideal is if I could just grab the lower-right corner of the window and resize it to what I actually want... well, I *can* do that, but the only thing that resizes is the outer frame; the rest of the dialog does not react to the resize at all.
So what ultimately happens is, I just keep switching between the three controls until I get something that I can live with, and just stick with that, but it's hardly ideal !!
So could anyone advise me on any techniques that I could use, to just set the program to the size that I actually want??
My system:
Windows 7 64bit
Nvidia GTX 980
Monitor: 30" 2560x1600
WD Version 10.37S53, running as Administrator
Offline bitsostring
  • WMR200
  • Edinburgh, UK
  • Win NT 10.0
  • Mozilla compatible
Re: long-standing frustration with WD
« Reply #1 on: August 12, 2017, 06:16:10 PM »
I sympathise. For what it's worth:
1. I use the no.2 control to set screen size 20% larger than normal, BUT I don't save this in Setup/Advanced or it gets another 20% larger every time you restart.
2. I set font sizes and move things around at +20%, BUT use the no.3 control to go back to normal size and save - even though the display may look horrible at normal size.
3. I then resize the window to +20% again. I've never found it necessary to restart.
It's meant to be fun. . .
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 60.0.3112.90
    • Weather Display
« Reply #2 on: August 12, 2017, 06:54:51 PM »
there are reasons why it is the way it is
and its related to the screen shot being a standard size (i.e the WD screen resizes)
(and that stems back to where there was dial up, a very large size screen shot was not ideal)
Offline gorlash
  • Win 7/Srvr 2008R2
  • Firefox 52.0
« Reply #3 on: August 12, 2017, 08:33:37 PM »
Thanks for the responses!!
bits'o'string: I'll try your technique, and see what happens!!
boss man:
Thank you for the history, that gives me some context!!
Is there any chance that you could consider adding a fourth mode, where the user specifies total window width and height, and the controls are resized to fit that??  That would be a more ideal solution in the modern world, where 700x500 (the reset size) is rarely of value to anyone...
Offline gorlash
  • Win 7/Srvr 2008R2
  • Firefox 52.0
« Reply #4 on: August 12, 2017, 08:45:18 PM »
Oh, wait... maybe I *do* understand this???
I think what control #2 is doing, is making the window "that percent larger than it already is" ...  is that correct??
I played around just now, with 20% and 30%, and the latter gets me very close to where I want to be...
The only thing that was ood, is that when I did "save and exit" and then reloaded, it didn't reload at quite the size that it was when I saved, but it looks great...
So *that* was the key point that I couldn't figure out: that control makes window "x% larger than current size", as opposed to "x% larger than 'normal' "...
Heh... cool...
