Author Topic: which station to choose for WH2600  (Read 574 times)
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 60.0.3112.90
    • Weather Display
Re: which station to choose for WH2600
« Reply #15 on: August 11, 2017, 09:58:07 PM »
you set your WU ID
and then it should update every 5 minutes
(you might need to restart WD)
email me your WU ID and I will test here
Offline ph_dec
  • Belgium
  • Win NT 10.0
  • Firefox 54.0
« Reply #16 on: August 12, 2017, 08:47:37 AM »
I really appreciate the advices you gave me.
I could find the 'json' file for my town from Wundrground :"  http://api.wunderground.com/api/0def10027afaebb7/conditions/q/BE/Morlanwelz-Mariemont.json " .
I use it in the station selection in WD, there are some results in the display but most not correct. I suppose the layout is different from the ' ws1001.json ' file format.
Nevertheless there are no info concerning my indoor conditions in my json file , so not possible to see them with WD.
From my IPobserver black box, I can see via the 'Weather Logger' the current live data. Checking the page code I can find all the conditions values. So I plan to find a way to extract my local indoor conditions from that page and log it.
I don't see in WD a station definition to read and format this 'live data' page.
I joint the picture of this live data page and a PDF of the source code.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #17 on: August 12, 2017, 07:16:10 PM »
when using the wunderground API
all you need to enter is your WU ID
I have tested here with the WU ID you emailed me and the readings in WD match your WU web site data
you can also set to use your own WU API key (I did not do that in the test above)
