Author Topic: Could be me but no data showing  (Read 560 times)
Offline stuee
  • Win NT 10.0
  • Chrome 59.0.3071.115
« on: August 08, 2017, 12:51:09 AM »
Hi when i use my WMR300 with weather display it wont show any details.
Ive tried different things and settings and it doesnt seem to show. I tried the history and that seems to be reading the unit i also have the correct software for the unit installed which reads it ok.
I have the latest WD Trial software (will purchase once i know it works properly)
Windows 7 x64  (have to use this for my boltek LD-350 lightning tracker)
Anything i can try. thanks
  • Davis VP2
  • New Zealand
  • Android 5.0.1
  • Chrome 59.0.3071.125
    • Weather Display
Re: Could be me but no data showing
« Reply #1 on: August 08, 2017, 01:17:05 AM »
One thing,make sure the time and date on the station
Console matches the pc time and date
What shows in the separate running wmr300decode program?
Offline stuee
  • Win NT 10.0
  • Chrome 60.0.3112.90
« Reply #2 on: August 09, 2017, 12:06:30 PM »
I changed the dates to the the same, it then ran history and all the details came to life, well that was for 6 hrs then its died, it gets the history from the device so its getting the connection. But its not showing anything at all and the data and history lights are red. tried restarting software and pc a few times and nothing.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: August 09, 2017, 07:34:25 PM »
Quote
Offline stuee
  • Win NT 10.0
« Reply #4 on: August 09, 2017, 09:34:37 PM »
I did mess with it more lastnight and found the clock on the console had changed the date 1 day forward some how? i changed it back and restarted the program and it worked.... showing all correct reading.... well that was till i left the pc alone, got up in the morning and it is showing the same details as last night and all graphs flat lined. Yet the data and history lights are flashing green.
Opening decoder now:
it shows device found WMR300, and constantly streams data.
the times are correct on the decoder to the computer clock, give or take seconds.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #5 on: August 09, 2017, 09:38:43 PM »
the date also needs to be correct
and the time, maybe you have it mixed up with 24 hour clock, i,e what you think is am time is pm time? (and so the date is then a day out for 12 hours of the day)
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #6 on: August 10, 2017, 09:12:54 PM »
Ideally I need to make it so that it does not rely on the date and time being correct
(by using the CRC error code more)
I could try doing that and you could test for me?
Offline stuee
  • Win NT 10.0
« Reply #7 on: August 10, 2017, 09:49:55 PM »
hi, im happy to test.
Im home all day today so will keep checking on here.
The problem im having is its connecting then when i leave the computer for a few hrs about 2 hrs after it all just flat lines and stops the live updates. Yet the data light etc is still going and receiving data but all graphs are flat.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: August 10, 2017, 11:08:51 PM »
re the problem when you are not at the pc
that might be to do with windows putting the usb to sleep maybe
make sure your pc is not set to any power saving modes (and selective usb suspend too) . I do have a youtube video showing how to set that all up
if you could use this test version
http://www.weather-display.com/downloadfiles/wmr300decode.zip
i.e unzip to where you have WD installed (close the current running wmr300decode program, then run this new version)
then copy and paste the raw data that should show in the area at the bottom of the screen and email or post that here
thanks
Offline stuee
  • Win NT 10.0
« Reply #9 on: August 10, 2017, 11:35:38 PM »
i did turn off sleep, and the usb power mode the other day and still the same, ill check out the video and make sure im doing it right :)
ill try that decode in a few and post results
Offline stuee
  • Win NT 10.0
« Reply #10 on: August 11, 2017, 03:01:11 AM »
month  8
day  11
hour  12
minute  55
channel # 1
temperature  24.6
humidity  59
wind  m/s 2.9
direction  147
year  2017
month  8
day  11
hour  12
minute  55
channel # 0
temperature  25.4
humidity  54
indoor temperature  25.4
indoor humidity  54
raw temperature #1 0 246
year  2017
month  8
day  11
hour  12
minute  55
channel # 1
temperature  24.6
humidity  59
barometer 1017.9
 checksum  529.0 529.0
last hour rain  0.0
24 hour rain  0.0mm 12:56:04 PM
total rain  0.0
 rain rate (.in/hr) 0.0
00 D3 3D 11 08 0B 0C 36 05 7F FF 7F 7F FF 7F FF 03 03 11 08 0B 00 00 7F FF 11 08 0B 00 00 7F FF 00 00 00 00 00 7F FF 00 00 00 00 00 7F FF 11 08 0B 00 00 7F FF 00 00 00 00 00 7F FF 0F DA 00 00 00
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #11 on: August 11, 2017, 03:41:18 AM »
try downloading a new update
the CRC checking should work now :)
(vers 2.9 of the data reader program)
Offline stuee
  • Win NT 10.0
« Reply #12 on: August 11, 2017, 03:56:31 AM »
where do i download the update from?> the website? that still shows 16th july?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #13 on: August 11, 2017, 06:14:34 AM »
