Can I have 2 WD programs running from same station
is it possible to have WD for windows and WD for Linux running at the same time and receiving data from my Davis Vantage Vue station.
Obviously this would need a suitable hub which has the correct usb socket, so it would 1 in and 2 out.
It’s something I’m curious about if it could be done
you could have done that via virtual VP (running on the windows pc) and set to share data via TCP/IP and set the linux version of WD to use that as a data source
