Author Topic: Davis VP Data Extraction  (Read 487 times)
Offline T and T
  • Powell, WY USA
  • Win NT 10.0
  • Chrome 59.0.3071.115
    • Powell Wyoming Weather
« on: July 31, 2017, 10:50:01 PM »
My Data Extraction window has quit extracting. On WD restart, the data extraction window opens, but the status bar doesn't do anything. On occasion it will hang and have to be manually closed, but most of the time it seems to eventually time out and close. I read in another post that the Davis logger may be full and to check 'clear data', restart. I normally have clear data checked. Any ideas?
WD 10.37S45
____________________
Terry
Offline NorCal Dan
  • Dan - KJ6RGX
  • Davis Vue/Win10
  • Ocean Park, WA.
  • Win NT 10.0
    • Traveling RV Weather
Re: Davis VP Data Extraction
« Reply #1 on: August 01, 2017, 04:58:01 PM »
Are you able to get "live" data after the failed extraction?  If so then I would do a master reset on the datalogger.  Shutdown WD, remove main power to the VP console, remove the batteries from the VP console, disconnect the datalogger from the VP for a few minutes.  Then reverse the process, install the datalogger, install batteries, apply mains power, and fire up WD.
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
« Reply #2 on: August 01, 2017, 05:03:21 PM »
The "clear data" option is not normally selected.
Offline Budgie
  • Martin
  • Global Moderator
  • CWOP: CW7959
  • Lochaber, Scotland
  • Win NT 10.0
  • Firefox 54.0
    • Lochaber-Weather
« Reply #3 on: August 01, 2017, 08:31:21 PM »
The Davis datalogger will just overwrite the oldest record with the newest one, so it never really gets full.
If you clear all the data after extraction and something goes wrong then you have no data if you want to try again.  :wink:
Offline T and T
  • Powell, WY USA
  • Win NT 10.0
« Reply #4 on: August 03, 2017, 07:55:40 PM »
Yes, Live data is fine.  I did a master reset of the data logger. After reset, WD couldn't see the data logger. Did a couple more re-boots and connected to the logger.
Terry
Offline NorCal Dan
  • Dan - KJ6RGX
  • Davis Vue/Win10
  • Ocean Park, WA.
  • Win NT 10.0
« Reply #5 on: August 05, 2017, 06:38:32 PM »
What datalogger (WeatherLink) are you using?  Serial, USB, TCP or 3rd party?  Since performing the master reset are you still having issues getting archived data from the datalogger?
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #6 on: August 05, 2017, 06:43:53 PM »
Do you know if a master reset clears the logger archive interval setting?  Maybe worth to reset that to 1 minute.
Offline T and T
  • Powell, WY USA
  • Win NT 10.0
« Reply #7 on: August 06, 2017, 05:58:15 AM »
I have the USB datalogger
Terry
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: August 06, 2017, 10:00:23 PM »
normally a complete power down of the console and then removal of the data logger for 5 minutes, then re power up console after putting it back in, and then setting the time/date and data logging interval (e.g 1 minute), works
Offline T and T
  • Powell, WY USA
  • Win NT 10.0
  • Chrome 60.0.3112.90
« Reply #9 on: August 07, 2017, 07:08:22 PM »
Got it! I changed the data logging interval to 1 minute and restarted. Thanks for all of the help everyone.
Is there a 'recommended' setting for data logging? As I understand it, uncheck 'clear data' in the pop up window, and use log at 1 minute intervals. Correct?
Thanks everyone
Terry
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #10 on: August 07, 2017, 07:53:53 PM »
that should work OK
