FTP not updating after restarting WD
Hey Brian
I know you aren’t doing much on the Mac side.
But if you are able, that issue where the FTP doesn’t come after restarting WD is somewhat annoying. I tend to forget to delete the wddisplayftpreal file many times
Just thought I would ask
does this issue happen every time you restart?
Yes… i forget to remove the file. Then like today at work, checking and still showing data from yesterday
even if you exit WD via exit, save and exit?
Mac version doesn’t have a save and exit - just exit
that does the same thing in essence
I suspect the problem is that when WD closes it forces the cronftpreal program to close which then corrupts that programs ini file
Hey Brian
No pressure… Just wondering if you had a chance to look at this.
With as many flat lines and mac lock ups I have had to restart mine so many times lately. I tend to forget to remove the file before restarting.
Thanks :slight_smile:
Hey…
So since you are on a fixing frenzy - LOL
This isn’t a showstopper by any means but more of an annoyance.
Any thoughts on this one??
I had already added code to delete the file on start up so that it gets recreated
Dang, my apologies… I missed that
Thanks !!!
Man you are on a roll !!!
Keep up the good work
