Hello,
I am having a problem with the customclientraw.txt generation in the correct format, I think. I wonder if someone could help with this.
The full error is “ParseError: SyntaxError: JSON.parse: Unexpected non-whitespace character after JSON data at line 1 columb 7 JSON data”
I have made the needed path change to where my cusomclientraw.txt file is located (it is the same place the clientraw.txt file is) in the root.
My installation of steel gauges is in the root too. I have verified the path is correct by downloading someone else’s customclientraw.txt and putting it in the root and it recognizes it and displays correctly on the gauges.
It seems that the customclientraw.txt that WeatherDisplay is generating is not in the same format as the customcientrawlocal.txt file that comes with Steel Gauges nor like the one that I downloaded from someone else.
I have the most recent version of WeatherDisplay and have in fact just updated it this morning to ver 10.37S53
I have the settings in WD set the same as the ones in Brian’s YouTube video and I think I have followed the instructions in the readme correctly.
I attach the customclientras.txt file and the setup page in WD. SORRY FOR THE CONFUSION. I UPLOADED THE CORRECT CUSTOMCLIENTRAS.TXT BEFORE. I NOW HAVE THE ONE THAT IS WHAT MY WD IS GENERATING.
Thanks for any help that you can give on this.
By the way, here is the link to the guages http://www.brantfordweather.ca/gauges-ss-basic.htm
Gary
customclientraw.txt (779 Bytes)
